Author Topic: Packed up fan....  (Read 2822 times)
Offline James Q
Packed up fan....
« on: 13 November 2011, 16:01 »
Right to day my fan decided to retire, car started over heating fan didnt kick in, i've heard theres a 'cheat' you can do to bridge a switch so that the fan is on constant? If so how is it done? I really need a quick fix till payday or i can figure out what has caused the fan to not work???
Car in question is a 91 mk2 Golf driver 1.6
Offline clipperjay
Re: Packed up fan....
« Reply #1 on: 13 November 2011, 16:25 »
So instead of fixing the thermo stat, you will knacker out the fan and add to your expenses?
My suggestion is to make your life really painfull is to wire the fan to a switching live through the cigi lighter then the switch can be on or off when you need it in traffic? Sounds like fun than getting a socket to change one thermo stat non?
 :evil:
Offline James Q
« Reply #2 on: 13 November 2011, 16:34 »
Thermo stat?
Offline clipperjay
« Reply #3 on: 13 November 2011, 16:37 »
On the rad there is a tiny thermostat it sense temperature to connect the fan to 12V if its knackard the fan won't come on. To test the fan stick 12V across the +- to establish if its working. it can only be thermostat or Fan 50/50  :wink:
Offline James Q
« Reply #4 on: 13 November 2011, 16:45 »
Ok cool, I will phone vw up tomorrow and see if they have one, dont suppose you know the part number?
Offline clipperjay
« Reply #5 on: 13 November 2011, 16:55 »
Better off ringing GSF or VW Heritage its gonna be cheaper mate!
Also known as a "temperature switch"
http://www.vwheritage.com/vw_spares_Thermo-switch-Golf-MK2-8-83-7-92-95-84C-2-Pin_act_shop.product_pID_48541377_lang_EN_country_GB.htm
£8.00 cheap as chips  :wink:
Offline James Q
« Reply #6 on: 13 November 2011, 17:02 »
Thank you :-)
Offline Santiago
« Reply #7 on: 13 November 2011, 17:30 »
Pretty sure it'll be the 3-pin dual thermoswitch on a '91 Driver.
191959481C
Offline James Q
« Reply #8 on: 13 November 2011, 17:34 »
Cool thank you, will this be the one that cuts in at 86 or 92oc?
Offline Santiago
« Reply #9 on: 13 November 2011, 18:03 »
Dunno where you got those numbers from.  The part number I've quoted has two thermoswitches in it, the first one operates at 95C causing the fan to come on at low speed.  If the temperature continues to rise, the second switch cuts in at 102C and switches the fan to full speed.
Before you buy anything though, check that the fan works.  Unplug the connector from the thermoswitch (down lowish on passenger side of rad).  With a thickish bit of wire, bridge the socket that the pure red wire goes into to each of the other two in turn.  Fan should come on at two different speeds.  No need to switch the ignition on, just keep your fingers/hands out of the way of the fan.
« Last Edit: 13 November 2011, 18:07 by Santiago »
