Author Topic: Engine Conversion....Ideas!  (Read 10262 times)
Re: Engine Conversion....Ideas!
« Reply #30 on: 11 November 2011, 16:17 »
2.9 rado CHW code? as the bhp on a 2.9 is 190 and me thinking CHW box will be just right (without a remap) or am i just talking bubbles? :grin:
VR6 box will not fit due to different bellhousing
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #31 on: 11 November 2011, 17:05 »
just fit a 16v box.. everyone does it  :wink:
you will be fine without LSD unless like me you are going for huge power
remember folks.. this is not a cheap game
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tweed
« Reply #32 on: 11 November 2011, 19:06 »
who got the dec PVW mag?
I've been waiting to read about that mk2 for years. I know it's a mk2 but I'm more interested in the 1.9 20v t build
buy it kids
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #33 on: 12 November 2011, 19:22 »
i know what you mean kells. LSDs start about the £700 mark? all they do is limit spinning the wheels??? what other benefit do you get from an LSD?
also which other box will fit the AMK/BAM engine? 2.9 rado CHW code? as the bhp on a 2.9 is 190 and me thinking CHW box will be just right (without a remap) or am i just talking bubbles? :grin:
An LSD basically transfers the torque to the wheel with the most grip as oposed to a normal diff which does the exact opposite. So as you can imagine, the power gets laid down a LOT better with an lsd because rather than just throwing more power through an already spinning wheel and costing you a tyre it transfers it to the other wheel, once that starts losing traction and the other starts gaining then it switches again  :cool:
Offline Dan_GTi8v
« Reply #34 on: 12 November 2011, 22:28 »
tbh unless you go mental power like kells you will be fine with a 16v box, you just need to be aware that planting your foot will get you wheel spin in 1st and 2nd, and 3rd if its wet or you are giving someone a good thrashing  :grin:
Offline sharki786
  • GOT BOOST??
« Reply #35 on: 13 November 2011, 00:00 »
cheers guys for that.
i have placed some parts on order to get the ball rolling as i know that if i dont it will neveer happen :evil:
16v clocks but as mine is anni i wanted the 16v anni clocks like kells but well see
16v loom
twin rad fan setup
clutch pedal (full setup in gear shifter)
16v rear mount
sorry ive high jacked someones thread :embarassed:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline benvictors
« Reply #36 on: 13 November 2011, 00:09 »
Your 8v loom will be fine mate, dont waste the money on a 16v one  :wink:
Offline danmusic24
« Reply #37 on: 13 November 2011, 07:54 »
What's happens with throttle cable can it still be used or do you have to go drive by wire?
Also is it a lot easier to start with a 16v? That way could you just remove engine and leave gearbox in.
Offline tshirt2k
  • Been there...Done that...
« Reply #38 on: 13 November 2011, 09:26 »
After a while, the spinning and not really getting anywhere gets boring and high cruising revs in 5th points to gearbox mods.
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
« Reply #39 on: 13 November 2011, 11:44 »
depends which way you go, Qpeng and you need a sh!tty cable and GTI TB, go for a early 20VT like a AGU, and you need to go cable as thats what these were
later engines were the better DBW... this is much better, but you need the accelerator pedal off the donor car as you have to wire it into the loom to the ECU
