Author Topic: Engine Conversion....Ideas!  (Read 10261 times)
Offline topher
  • Administrator
  • fully functioning
Re: Engine Conversion....Ideas!
« Reply #10 on: 08 November 2011, 19:10 »
1.8t ftw, quite a simple conversion now, especially with a GTI and even more so with a valver. A tuned K04 lump is more than enough for a bit of fun.
There is a PnP kit for the 2.0T now isnt there?
using the stock bosch med9 ecu apparently too. i think possibly qpeng have figured out which parts of the loom you can do away with, de-immoblised the ecu and turned off some of the can related shiz.
i might have to have a bash.. :nerd:
Offline sharki786
  • GOT BOOST??
« Reply #11 on: 08 November 2011, 22:10 »
[/quote]
topher who does the BAM engine loom modding and how much would it cost to do? as im too thinking about going down kells route as my mates a mech and knows his stuff about the bams (he has a cupra R BAM remapped) and i drove it and felt just like mine but with LOADS more powaaah. another reason is that the 1.8t is alot more fuel eco than my 8v or a VRG :tongue: and he pushed me to go for the BAM lump :lipsrsealed:
*****MK3 Anniversary*****
*****MK4 GTI T*****
VW BUSH
« Reply #12 on: 08 November 2011, 22:16 »
Its not two VW's bolted together is it? thats a long time to go un discovered :undecided:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #13 on: 08 November 2011, 22:21 »
i can do the conversion for you at a good price if you supply all the bits.. using the OEM looms and ECU  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline sharki786
  • GOT BOOST??
« Reply #14 on: 09 November 2011, 10:03 »
thanks for the offer kells bud. i want to do it myself and my mate who knows his stuff about bams is going to help me. what about the loom? what would you want to charge to mod the loom for me if i provide it to you next time im up in dews?
*****MK4 GTI T*****
Offline Dan_GTi8v
« Reply #15 on: 09 November 2011, 14:01 »
rubjonny can do a loom for around £100 if you supply the 16v mk3 and 1.8t loom
Offline LazyLunatic
  • MK3 20VT Project
« Reply #16 on: 09 November 2011, 16:56 »
Offline sharki786
  • GOT BOOST??
« Reply #17 on: 09 November 2011, 23:10 »
it has to be the mk3 16v loom or could it be the mk3 8v loom? what about the ecu?
also does the MFA work with the modded loom?
*****MK4 GTI T*****
Offline Dan_GTi8v
« Reply #18 on: 10 November 2011, 03:58 »
I guess ideally you would want the loom for the car you are going from so you can use the same fan control switch relay and a couple other things I cant remember off the top of my head, 99% of the plugs are the same on all mk3s for the things you will be keeping so it doesnt matter too much. I used a 16v loom as I couldn't send him my 8v loom due to my car being my daily driver. Drop him a pm, he's the most helpful guy in the world no question is too much and I should know with the amount of random noob questions I sent his way while I was doing mine  :grin:
Everything including mfa works just as it did in the mk3, only thing that wont work out the box so to speak is oil temp but that can be fixed by adding a t-piece with a temp sensor into one of the pressure sensor lines
Offline LazyLunatic
  • MK3 20VT Project
« Reply #19 on: 10 November 2011, 12:08 »
I'll second that about rubjonny! No question is too much, never failed me and always really helpful and friendly!
