Author Topic: Need new rear brakes - Recommend the pads  (Read 4779 times)
Offline Khare
  • The bear that khares
« on: 06 November 2011, 17:00 »
Had my MOT yesterday and although my only two advisories were the rear bearings, the discs and pads are getting low.
Up front I have 288mm discs with Mintex M1144 pads, which are great. At the back I'm looking for something a bit less aggressive. I've sourced a pair of brand new discs from an average manufacturer (Trupart). Padswise it's bewteen these two.
http://www.ebay.co.uk/itm/MINTEX-REAR-BRAKE-PADS-VW-GOLF-MK3-GTI-2-0-93-97-MDB1377-/330614391021?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cfa2740ed#ht_4033wt_1002
or
http://www.ebay.co.uk/itm/Rear-Brembo-Brake-Pads-VW-Golf-Mk3-2-0-Gti-91-96-/400181481921?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2cacd1c1#ht_2505wt_952
As I've already got Mintex up front I'd quite like to keep Mintex setup all round, however if the Brembo's are better then I'll go for them. So, please share your thoughts  :smiley:
VW BUSH
Re: Need new rear brakes - Recommend the pads
« Reply #1 on: 06 November 2011, 17:11 »
Remember rears do little or no work until you have weight in the back, and then its limited by the bias valve.
Its a non track car so stay with the cheap disc theme and go for some hard wearing ATE or Pagid imo, you can tell people they are all mintex as nobody will know or care  :smiley:
Offline Khare
« Reply #2 on: 06 November 2011, 17:17 »
No bias valve on the Mk3's as far as I know  :undecided: At least on the GTI's anyway. Don't want hard wearing pads as they'll be no feel on the brakes.
VW BUSH
« Reply #3 on: 06 November 2011, 17:28 »
You wont notice the extra dosh on rear pads either on the pedal or stopping distance.
Unless you have a power monster 1.8t and or track car with uprated discs and braking set up it is a waste of money.
I Have gone through sets of EBC on the front discs without changing the rears they do bugger all.
Best off spending more on the fronts, bigger discs calipers etc if you want stopping power.
By all means its your dosh but it will only be for the kudos of saying Mintex/Brembo all round  :smiley:
VW BUSH
« Reply #4 on: 06 November 2011, 17:30 »
Search Akebono, very good brake manufacturers :cool:
Offline tweed
« Reply #5 on: 06 November 2011, 17:42 »
rears do work.
I had no abs in my 16v. I had greenstuff up front and mintex rears. the rears used to lock up when braking hard on cold brakes. once the greenstuff warmed up it was alright and they locked up lol
get the mintex
Offline Khare
« Reply #6 on: 06 November 2011, 17:43 »
Cheers mate, it's what I was thinking. The front mintex are great quality, no doubt the OEM quality stuff is just as good!
Offline Khare
« Reply #7 on: 06 November 2011, 17:46 »
Bought them. Cheers for the help guys, and VW BUSH thanks for trying to persuade me to buy something else  :grin:
Offline tweed
« Reply #8 on: 06 November 2011, 18:05 »
they're what I had. good pads  :wink:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #9 on: 06 November 2011, 19:31 »
Iv got Mintex discs and normal mintex pads on mine.. i running a lot of power.. they do a grand job. nuff said  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
