Author Topic: Need new rear brakes - Recommend the pads  (Read 4784 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Need new rear brakes - Recommend the pads
« Reply #20 on: 06 November 2011, 21:37 »
well my remap has not been done yet, well their is a very basic base map on and its around the 250 bhp, 280lbft mark
after the map has been done it will be around the 270 bhp mark
Next year I'm looking at a GT28 or a GT30 Big turbo kit.. so we are looking at anything from 350 to 400 bhp.. need some very Good brakes for it. seen a few kits i like but its all ££££   :lipsrsealed:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline AudiA8Quattro
« Reply #21 on: 06 November 2011, 21:46 »
Stand back and wait for it to go bang  :lipsrsealed: :grin:
Offline F17BAD
« Reply #22 on: 06 November 2011, 21:51 »
internals can cope with 350 standard, but ill be uprating the con rods to be safe..  will be genuine power too and not just made up figures like most peoples are
« Reply #23 on: 06 November 2011, 21:54 »
I read that the bottom end is good for 400bhp, not sure if its true though, that's why the block is so heavy.
Brakes and LSD next then.
Offline F17BAD
« Reply #24 on: 06 November 2011, 22:05 »
yeah 400, but id never wanna push it so far hence why i say 350..
deffo brakes and deffo a LSD needed.. everything is expensive tho so i have to choose what i got for very wisely. the car is extremely fast as it is, it does not need much more to keep up with most things on the road (or even beat them), but no point having the power their if you can't get in onto the tarmac  :smiley:
« Reply #25 on: 07 November 2011, 10:59 »
Your limited by wheels in a way, unless you switch to bigger wheels 312mm is the biggest you can run.
« Reply #26 on: 07 November 2011, 12:04 »
312mm should be good enough.
« Reply #27 on: 07 November 2011, 13:45 »
Guess so but what is the limit, 350bhp is asking a lot.
VW BUSH
« Reply #28 on: 07 November 2011, 14:21 »
not exactly right but i get the point  :cool: Heavier the vehicle , the more stopping power required.  :nerd:
I meant all cars the same weight  :grin:
Put myself and Brad's car as an example. If we're both on the motorway and we both brake we're going to require the same stopping power, even though he's got 100hp more than me  :smiley:
This is only accounting for a "freewheel situation" with the car in gear and breaking with the clutch engaged you will find Brads pads are going have more resitance from the engine therefore be under a lot more load. Brad has 100bhp more than std abf and I dare say at least twice the torque and maybe some more weight so he will need a high load friction material to be able to stop it while not burning up on those "Private road test sessions" at high speeds :wink:
The rear pads do very little work in comparison to fronts on both std and track cars, if your rear brakes lock up then you will find the back end is going the wrong way very quickly.
( A very good reason to not have sticky/siezed calipers on the rear of your car)
Even on non abs cars you will see a car in full skid with the fronts locked and the rears still spinning
This is why cars are biased with more stopping power to the front wheels (this is done via a valve or by feed diameter) so that they have more control under heavy braking or in a skid.
In a standard Mk3 Golf or any other Hatchback car of its ilk you will find the rear stopping power more than adequate for the car and very very difficult to glaze over or burn the friction material.
This is why uprated pads and discs on the rear of a normal car are more about kudos than actual improvement.
Trust me I have sat the exam got the certificate and built the hydraulic rig to test the friction material
The fronts however are a very different story :smiley:
As said it is your choice and money all along and for £20 it aint gonna hurt is it :cool:
« Reply #29 on: 07 November 2011, 14:36 »
Mine is 312mm, 300bhp with auto transmission, that's alot work  :laugh:
