Author Topic: VW Sharan and Vag Tacho  (Read 3893 times)
Offline Ant1981
  • Feed me, prod me
« on: 25 October 2011, 18:55 »
A mate of mine has a 2001 Sharan and he'd like a key programmed. I've vag tacho 3.01 which on his car comes up with a fault to ground. On my car it works out ok. Could this be that the Sharan needs vag tacho 2.5
Cheers.
Edit, he's damaged the immob chip in the key, I'm guess that this will prevent us from getting a connection to his immobiliser in the first place?
« Last Edit: 25 October 2011, 19:06 by Ant1981 »
'09 Kawasaki Ninja ZX-6R
Offline bricey
  • One of a few with a PROPER engine
Re: VW Sharan and Vag Tacho
« Reply #1 on: 25 October 2011, 19:37 »
from wat i have read all evening 2.5 is the one you need
DOLPHIN TRAINER
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 26 October 2011, 21:25 »
Maybe try to disconnect the radio. May be a problem with the k line! Does vag com work with it?
Mk3 ABF 16VT Megasquirt V3
Offline Ant1981
  • Feed me, prod me
« Reply #3 on: 26 October 2011, 21:27 »
Yeah vag com worked ok.
Offline tshirt2k
« Reply #4 on: 26 October 2011, 21:30 »
You should be able to connect to the clocks without a working key. Can it see the clocks? It may be something to do with the ford similarities.   :undecided: can't say I've tried it on these.
Offline Jay
  • balding fat cvnt
« Reply #5 on: 26 October 2011, 22:18 »
100% German engineering (actually Spanish as they were assembled there) on the Sharan. The only Ford things were on the Galaxy's were the 2.3L engines, related hardware for the 2.3L and the badges oh and the clocks for the 2.3, and the extra storage on top of the dash and heated front screens. That's about it.
Offline Ant1981
  • Feed me, prod me
« Reply #6 on: 28 October 2011, 08:45 »
Because the immob chip in the key was damaged access was blocked, so the main chip in the clocks was taken out by a mobile tech/key company, chip placed on a test board and read for the code, then put back in and new keys coded.
Offline tshirt2k
« Reply #7 on: 28 October 2011, 14:18 »
You should still be able to get pin from clocks without a working key. I've done it many times with a blank.
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 28 October 2011, 17:21 »
But you would have had a working key in the barrel to wake up the immobiliser. We didn't have ANY key.
Offline tshirt2k
« Reply #9 on: 28 October 2011, 18:19 »
You mean, you couldn't even turn on the ignition?
