Author Topic: wishbones on a 1.4  (Read 4644 times)
Re: wishbones on a 1.4
« Reply #10 on: 22 October 2011, 23:45 »
How would I know if that had happened? all looked ok but wasn't sure what I was looking for tbh I've not worked on a 1.4 before
Any chance of a pic  :smiley:
Offline tweed
« Reply #11 on: 22 October 2011, 23:58 »
why don't you just undo the engine mounts and jack the engine up?
Offline renzo
« Reply #12 on: 25 October 2011, 00:52 »
Yeah Dan came round and we managed to do naff all, we'd start one thing and find round bolts done by someone else :angry: :angry:
Good thing is I found the top struts caps £6 a corner from TPS  :grin:
Anyways here's a pic of the engnine blocking the wishbone bolt  :sad:
Think the only way is as tweed says, take it off the mounts and lift the engine a bit.
Quick question, will I have to undo both the both the back and front mount or just the one of them?
Offline renzo
« Reply #13 on: 25 October 2011, 00:54 »
Offline hotdogsmale
  • You just cant go wrong with a golf!
« Reply #14 on: 25 October 2011, 14:08 »
i have a 1.4 se mk3 golf ill take a pic of mine for you hope it helps
Offline hotdogsmale
« Reply #15 on: 25 October 2011, 14:17 »
Offline tweed
« Reply #16 on: 25 October 2011, 16:51 »
back will do. But I would do front and back
Offline Bellend
« Reply #17 on: 25 October 2011, 19:29 »
Yeah pretty standard on all MK3's and Polo's (6n) with Polo engines to have to loosen the engine mount and jack the engine up.
Only a 13mm then a 15/16/17mm bolt IIRC.
Did mine a little while ago, the sumps sit back for some reason.
Where all my moneys went.
Offline Dan_GTi8v
« Reply #18 on: 25 October 2011, 22:29 »
stupid ass design, as it was all so easy on my gti I figured there must of been something wrong. Not heard from him for a while so I guess its all going ok :P
Offline renzo
« Reply #19 on: 27 October 2011, 21:03 »
Does anyone know what the bit circled below is?
It seems to be stuck to the brake caliper along with the rubber boot, but it looks like a metal sleeve?
Only reason I'm asking is I want to cut through this and the caliper bolt so I can get the caliper off.
Loosing patience with these seized bolt things, and having to do major workarounds. Should be so simples
thnx
