Author Topic: wishbones on a 1.4  (Read 4645 times)
Offline renzo
Re: wishbones on a 1.4
« Reply #20 on: 27 October 2011, 21:05 »
this is the pic I meant to put up. :grin:
Offline Bellend
« Reply #21 on: 27 October 2011, 22:50 »
WTF are you trying to undo?  :huh:
That's the slider, don't cut it.
On the back of the calliper there are two (7mm IIRC) allen key bolts, these are the bolt/slider (it's one piece) for the callipers. There is normally two end caps on, remove the end cap, undo the 7mm bolts and the calliper will come off.
The top slides out to the side then will lift straight off.
No idea what you're trying to undo as there aren't any carriers.......
Where all my moneys went.
Offline tweed
« Reply #22 on: 27 October 2011, 23:05 »
I say have some fun and get a grinder out  :rolleyes: :grin: :grin: :grin:
Offline Dan_GTi8v
« Reply #23 on: 27 October 2011, 23:10 »
the pic is of the top bolt, we got that one out pretty easily. the problem is the bottom one is totally rounded off the allen just spins in the hole. Its different to the gti setup, iirc that just needs 2 13mil spanners on it, this is 6mil allen
Offline tweed
« Reply #24 on: 28 October 2011, 15:34 »
drill a hole in the center of bolt and use a outer  :wink:
Photo0374 by tweedub, on Flickr
Offline Bellend
« Reply #25 on: 29 October 2011, 00:21 »
I'd advise smacking in a spline tool.
That's what I did when mine rounded.  :wink:
Alternative is yeah, cut it and take it out with mole grips.
Offline Seanl
« Reply #26 on: 29 October 2011, 09:08 »
One of mine rounded off when I replaced my rears a couple of weeks ago. Managed to get it off with a set of Stilsons but ended up with blisters all over my hand and fingers though.   :rolleyes::smiley:
Offline madmanmart
« Reply #27 on: 29 October 2011, 16:50 »
What he said, Stilsons.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Bellend
« Reply #28 on: 30 October 2011, 11:42 »
Can't really get stilsons in there guys and is a hard thing for a drill.
Trouble is the bolt is sunk into a rubber sleeve so in as you mash that or try and pull it off you can't get them on it.
Offline Dan_GTi8v
« Reply #29 on: 30 October 2011, 14:20 »
He cut the sleeve and gave it to an engineer guy to sort out, then bought a new sleeve for £5. sorted!
