Author Topic: not holding boost 1st or 2nd????  (Read 3786 times)
Offline jamie1989
« on: 08 October 2011, 21:41 »
I have had a stage 1 R-Tech remap before fitting my FMIC.
I have got a boost gauge fitted and I am 80% positive it used to hold 14psi through all gears before fitting the FMIC.
But now Ive fitted the intercooler I have noticed only 1st and 2nd will spike to 14PSI then drop slowly to 10ish but 3rd, 4th and 5th its holding 14.
Is this right or am I going loopy? It doesnt seem any faster or slower its just something bugging me atm.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: not holding boost 1st or 2nd????
« Reply #1 on: 08 October 2011, 22:05 »
It sounds about right for 1st/2nd gear as there is very little loading on the engine, try it up a very steep hill in 2nd and you will find it will hold boost better.  For a spec1 remap it should be peaking a little higher closer to 18psi then tail off the 14psi on the higher gears? You could have a weak actuator?
 01455 617233
Offline james2
  • No scammers please.
« Reply #2 on: 08 October 2011, 22:06 »
i would only use a fmic for stage 2 .I would hate to get lag. :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline jamie1989
« Reply #3 on: 08 October 2011, 22:23 »
Thank god for that  :smiley: I will check the higher gears tomorrow and im sure I will find a nice hill to climb in sunny south wales haha.
Ohh yeah Nick I found out why my car was only boosting 4psi a week after your remap, The crank shaft sensor failed. I had it checked on vagcom bought a genuine one from VW and the little beast woke up again  :grin:
 James2 I havent noticed any lag mate if im honest.
Offline james2
« Reply #4 on: 08 October 2011, 22:28 »
lol my cam shaft sensor failed after r-tech remap .I thought the timing was out,as a friend changed it 5 days before. :laugh:
Offline jamie1989
« Reply #5 on: 08 October 2011, 22:37 »
How random is that lmao
I need more power in my life  :sad:
Offline james2
« Reply #6 on: 08 October 2011, 22:47 »
you know that, i need a thumper turbo 1000 bhp+.  :drool: skyline from hell.  :drool:
Offline james2
« Reply #7 on: 08 October 2011, 22:48 »
Offline james2
Offline Ant1981
  • Feed me, prod me
'09 Kawasaki Ninja ZX-6R
