Author Topic: advise needed  (Read 3158 times)
Offline djmagpie
advise needed
« on: 06 October 2011, 01:02 »
i have a 1999 golf turbo agu finding it hard to get it 2 all gears will go in but really rough and knochey seems to b getting worst do i need a new gearbox ??? just had a g60 flywheel fitted and vr6 clutch
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline Tazzy
Re: advise needed
« Reply #1 on: 06 October 2011, 02:57 »
check fluid levels
If It Comes Off, Modify It!
Offline houston
Re: advise needed
« Reply #2 on: 06 October 2011, 08:03 »
Gear linkage alignment needed, prob just cos the box has been off
Offline benmanc
Re: advise needed
« Reply #3 on: 06 October 2011, 09:11 »
Its easy if its gear linkage...
http://www.youtube.com/watch?v=tp9ggefOjAE
Offline rio_gti
Re: advise needed
« Reply #4 on: 06 October 2011, 09:19 »
you beat me to finding it!!!  :laugh:
Offline benmanc
Re: advise needed
« Reply #5 on: 06 October 2011, 09:23 »
 :grin: yeahh haha.  Had it in my bookmarks bar as I done it other day.  Need to make sure you get something to tightly fit the alignment gap as I found out the hard way after using a nail it wouldn't go in 5th and made it worse until I did it with a thicker nail
Offline djmagpie
Re: advise needed
« Reply #6 on: 06 October 2011, 11:47 »
it was like it before i had the clutch done .thanks for the link ill try it later see how it gose :smiley:
Offline djmagpie
Re: advise needed
« Reply #7 on: 06 October 2011, 15:08 »
just tryed the link adjustments as showed in the vid and mine dont look anything like on the vid ??
Re: advise needed
« Reply #8 on: 06 October 2011, 15:19 »
Check the oil quality and level 1st, might be worth changing the oil.
Offline djmagpie
Re: advise needed
« Reply #9 on: 06 October 2011, 15:22 »
Gearbox oil was done wen clutch was fitted 2 weeks ago
