Author Topic: advise needed  (Read 3162 times)
Re: advise needed
« Reply #10 on: 06 October 2011, 15:24 »
Gearbox oil was done wen clutch was fitted 2 weeks ago
Well in that case I would seek advice from the garage that fitted the clutch, something does not sound right.
Offline djmagpie
Re: advise needed
« Reply #11 on: 06 October 2011, 22:36 »
cheers m8 did have this prob before clutch was fitted
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline benmanc
Re: advise needed
« Reply #12 on: 07 October 2011, 08:13 »
Try the gear linkage then, if your unsure still from the advice given then seek help from a garage
Offline gavgtiturbo
Re: advise needed
« Reply #13 on: 07 October 2011, 22:38 »
My agu was different to this vid.To do mine im sure i undid a 10 or 13mm nut on the gear linkage in the engine bay while out of gear and moved it slightly,it was far easyer than in the vid and quicker. If i get chance tomorrow ill get a picture of what to do as its worth a try...Also the gear linkage bush may be warn as its quite common too(nice cheap fix though if it is).
Offline jnufcuk
Re: advise needed
« Reply #14 on: 08 October 2011, 16:44 »
Its easy if its gear linkage...
http://www.youtube.com/watch?v=tp9ggefOjAE
how easy is this to do? Are the levers etc easy to get to (its not a take engine out jobby is it)? Thanks as i owuld like to try this if its as easy as it looks in the vid as mine doesnt always go into 1st :sad:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: advise needed
« Reply #15 on: 08 October 2011, 17:50 »
easy as long as you don't have stuff in the way like I have lol
Offline jnufcuk
Re: advise needed
« Reply #16 on: 08 October 2011, 19:11 »
Just had alook and seems to be easy enough. Will give it a go when I get a chance
Offline houston
Re: advise needed
« Reply #17 on: 08 October 2011, 21:17 »
Just make sure whatever you put in the hole on the inside of the car by the gear knob fits snuggly.
I put an allen key bit it and it wouldn't work.
Use a nail like the guy suggests.
Also my locking mechanism for the shifter on the actual box is absolute crap and takes ages to find.
You can do it.
I did it for crying out loud  :cool:
my lock on the box was knackered so i did it in neutral, just need to be a bit more careful of knocking when you release the springs
Offline djmagpie
Re: advise needed
« Reply #18 on: 10 October 2011, 09:56 »
cheers m8 that b a help  :smiley:
