Author Topic: sub has a mind of its own  (Read 2656 times)
Offline magsmagsmags
  • Mk4 Golf GTI 1.8T (AUM)
« on: 26 September 2011, 19:32 »
Absolutely no idea what's going on
sub keeps making noises by itself, whether the stereo is on or off.
I've checked the connections on the back of the sub etc and nothings touching - i'm clueless. any ideas?
~Mags~
Offline Len
Re: sub has a mind of its own
« Reply #1 on: 27 September 2011, 08:55 »
Well it must be getting signal from somewhere! Unless you have Gremlins in your car!
Suggest you thoroughly check all amp and sub wiring.
www.sas.org.uk
www.the-ace.org.uk
Offline gti gaz
« Reply #2 on: 03 October 2011, 20:54 »
make sure you have a realy good earth my mrs ex fitted the one she has in her pug and was kinda doing the same gave it a real good earth and problem solved
 Any one in cornwall lets sort more meets!!!!
Offline Tazzy
« Reply #3 on: 04 October 2011, 11:58 »
check every single cable, power to amp, the fuse should be as close to the battery as possible, amp earth, should be the shortest cable in the set up, onto the nearest bare body panel as poss, remote, wire up right to the HU, and make sure your RCAs are going down the other side of the car to the amp power cable  :smiley:
EDIT: ive just spoke to a mate who certainly knows his stuff about audio as he has one of the loudest cars in the country in his class, what amp is it? as he said the on/off switch on the amp could be shot depending if its an old amp, something quite simple really  :rolleyes:
« Last Edit: 04 October 2011, 12:10 by Tazzy »
If It Comes Off, Modify It!
Offline km
« Reply #4 on: 06 October 2011, 10:50 »
my sub did this, but the amp was constantly turned on. it kept setting my alarm off overnight :grin:.
i just made a switch to turn it off :smiley:
