Author Topic: 16v turns over but will not fire... Help please  (Read 2890 times)
Offline walchy01
« on: 10 September 2011, 18:06 »
Hi all
Just gone back to my car to get home and it won't start;(
Turns over but will not fire up, checked plug leads, dizzy cap nothing loose etc
Anything else to look at, don't want to leave it in the car park where it is currently stuck :sick:
Thanks in advance
Offline The Mighty Elvi
  • I'm better than you today.
Re: 16v turns over but will not fire... Help please
« Reply #1 on: 10 September 2011, 19:14 »
Try bump starting it.
Offline walchy01
« Reply #2 on: 10 September 2011, 19:28 »
no joy with that either, sorry forgot to mention that...
Offline Lewy
« Reply #3 on: 10 September 2011, 19:32 »
Fuel pump buzzing when turning the ignition on?
Offline walchy01
« Reply #4 on: 10 September 2011, 19:33 »
yes its doing that  :smiley:
Offline Lewy
« Reply #5 on: 10 September 2011, 19:39 »
When was the last time it was started/used?
Offline walchy01
« Reply #6 on: 10 September 2011, 19:47 »
went to work, back home then down to a cricket match, turned it off about 12.15pm, tried to start at 17.30... and no joy :sad:
Offline Lewy
« Reply #7 on: 10 September 2011, 19:55 »
Engine earth, immobiliser, has the distributor got any signs of oil below the rotor arm?  Has it got a spark?
Offline walchy01
« Reply #8 on: 10 September 2011, 20:01 »
not checked engine earth tbh,immobilzer is switching on/off ok,nothing below rotor arm that i notice, spark not sure, it was pissing down here so tried a few things then got a lift home while the offer was there so left the car in a car aprk :cry:
Offline walchy01
« Reply #9 on: 10 September 2011, 20:05 »
whats easiest way to check for spark?? in the dark on my own :sad:
