Author Topic: 16v turns over but will not fire... Help please  (Read 2891 times)
Offline Lewy
Re: 16v turns over but will not fire... Help please
« Reply #20 on: 11 September 2011, 21:10 »
Another thing to look at is the ECU connection.  Mine was playing up and (this might sound strange) if I slammed the door in a rage at it not starting, it would fire.  It turned out the be one of the pins in the multi-plug connector not quite being closed up enough to make a good connection.
The way I found the problem was to wiggle the connector when it was running and it'll misfire and try to cut out.
Offline walchy01
« Reply #21 on: 12 September 2011, 14:30 »
Thanks mate, I'll try that too, top help
Thanks
