Author Topic: Is putting a K&N airfilter (57i) on my 8v a waste of time and money...thoughts?  (Read 3666 times)
Offline evereddy
Is putting a K&N airfilter (57i) on my 8v a waste of time and money...thoughts please?
on the uspide I dont think the airfilter had ever been changed cleaned....(95,000 miles).
apart from sounding good  :laugh: is there much benefit?
sorry couldn't find any other threads on this..
Offline trog_nfs
waste of money.
Smoothed and drilled airbox with panel filter and cold air feed.
I'm surprised you didnt get any search results though, it is covered pretty much every day
Offline evereddy
crikey - you really do live here Trog..!  :grin:
cheers, again....
Offline harlemex
Just agreeing with Trog, but thought I'd add that a less restrictive panel filter such as K&N or pipercross etc. Although they are still well overpriced.
Offline jiminbmth
  • brings back the sunshine!
trog +1,Smoothed and drilled airbox with panel filter and cold air feed. I went down this route.
however they do look better!!! And I do have one If you want 1,pm me!!! :wink:
jiminbmth ;)
Offline WadGTI
  • Golf GTI'er
I was thinking about doing this. I guess to smooth the box out you have to break the fins off with a pair of plyiers?
Thanks
Offline trog_nfs
Easiest way is to break the fins off and use a mini-dremel to smooth them down
Offline AudiA8Quattro
Does a smoothed airbox really make any difference? compared to just fitting a k&n panel with a cold air feed?
I have not bothered on mine but was told it helps in a little way.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
smoothed and drilled box wont do fack all either apart from let dust and moisture in, nor will a expensive panel filter  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
