Author Topic: Is putting a K&N airfilter (57i) on my 8v a waste of time and money...thoughts?  (Read 3671 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Been using K&N's since the early 80's.
I even rate them so much I actually bought one for one of my company cars!
 :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
VW BUSH
K&N filters rock, I wash mine out in the sonic tanks at work and never bother with oil other than a quick squirt of maint spray.
My current filter is upwards of 60k miles and on its third Mk3.
Paid about £30 for it 6 years ago so its paid for itself and bought me a beer :cool:
As for performance, it wont do dick on its own but allows you to exploit other areas better
Got some more pics somewhere, but i have been working through my intake in prep for a hot cam.
Gone away from drilled box and fitted bigger bore intake into original wing compartment (minus inner part of grommet, pipe on in 90mm elbow is for show only you need to cut the end at an angle so you dont seal off against the inner wing :wink:
Leave hood part of box alone fecking with this makes the car run pants.
I have also opened out my maf housing, dont feck with the Ali baffle or sensor tunnel :cry:
This one is now polished up gleaming with a new custom baffle.
Throttle body is now fitted, polished and enlarged+ matched to fit intake Manifold better.
Tip, use thin blade like half a power saw or strip of metal and heat it up very hot (be careful)
cut through ribs inside the base of the air box to smooth off, makes it easy to tidy them afterwards :smiley:
Got a nice exhaust fitted and a sport cat to go on, found a cat only part which i need to weld into the system cost me £80 :cool:
Car revs up quick and feels more responsive, cam will come when I can find the money for now PB cam will suffice
Is it worth tuning an 8v? dont care it gives me something to do and i spend some quality time with my dad in his workshop also its cheap fun.
One big problem with K & N is that they are oil and they tend to screw up the Maf sensor over time.
Pipercross foam is dry so gives no problem.
Offline AudiA8Quattro
I've never lost a MAF from using a k&n.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Likewise, and I've used them on several cars over the past 15 years. I can see this happening it you're stupid enough to dip them in ridiculous amounts of oil though.
Offline F17BAD
yep that oil thing is another internet K7N haters tale wayne mate, id ignore it coz iv never ever had that issue. always used K&N from my very first car in 1994 to present
