Author Topic: Cheep, cheep, squeek squeek  (Read 1945 times)
Offline harlemex
« on: 03 September 2011, 22:11 »
...coming from pulley area. Things I have done:- checked tension of pulley belt(newish belt)
        removed it altogether briefly(noise gone)
        checked routing also
        replaced water pump
        replaced cambelt
 The noise is really bad but gets better after about 15 mins driveing and dissappears on tick over. Any help would be really appreciated.
Offline Screech16v
  • MK3 20vt AGU
Re: Cheep, cheep, squeek squeek
« Reply #1 on: 03 September 2011, 22:36 »
Try a bit of wd on the belt tensioner  :smiley:
Offline harlemex
« Reply #2 on: 03 September 2011, 22:48 »
would that be the cambelt tensioner?
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 03 September 2011, 23:09 »
No the aux drive belt tensioner,you mentioned that the belt was briefly removed and the noise was gone,if that dont work ,spray a bit on the belt its self and in the pullley groove it wont do any harm and may help isolate where the sqeak is coming from,maybe try another belt,other things are water pump , alternator,PAS pump.
« Last Edit: 03 September 2011, 23:14 by Screech16v »
Offline harlemex
« Reply #4 on: 04 September 2011, 10:43 »
cheers for the reply. Soaked the area with wd and noise still present  :sad:
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 04 September 2011, 12:49 »
Mmmm strange one,the noise definatly went when the aux belt was removed? did you change the cam belt and tensioner because of the noise,check the plastic cover is not fouling the belt,i know you have probably done this but just trying to work it out :undecided:.Have you got an aircon pump?
Offline justalex81
« Reply #6 on: 04 September 2011, 13:41 »
bearings prob gone on whatever the aux belt drives on your car i.e alternator/power steering pump.
Offline gasketface
Offline harlemex
« Reply #8 on: 06 September 2011, 12:04 »
Cheers for all your replies guys. Problem solved. I checked the alternator first time round by simply removing the belt and spinning its pulley. No noise. Anyhow, investigated again yesterday and spun the alternator pulley by hand again but this time in the correct direction :wink: and hey ho there was the noise. Weird how it only makes this noise when spun in only one direction?
