Author Topic: noise from suspension, what to try next  (Read 1938 times)
Offline Dan_GTi8v
« on: 24 August 2011, 22:40 »
I've been getting a kind of knocking noise (cant think of a better word) coming from my front wheels/suspension. So far I've changed top mounts, wishbones, balljoints, and drop links. What else can I try, what started as a mild annoyance is starting to drive me mental!
cheers :)
Re: noise from suspension, what to try next
« Reply #1 on: 24 August 2011, 23:47 »
Are the top mounts tight enough
Offline stainesy
« Reply #2 on: 25 August 2011, 06:41 »
do you have coilys or springs?
Offline Seanl
« Reply #3 on: 25 August 2011, 08:37 »
Cv joint/boot
Offline Dan_GTi8v
« Reply #4 on: 25 August 2011, 08:51 »
Cheers for responces :)
As tight as I can get them
springs and shocks, 40mm wietecs
Cv joint/boot
How much work is this? cant find anything in haynes about it but everything else was easy enough
Offline Seanl
« Reply #5 on: 25 August 2011, 10:05 »
Depends if its inner or outer. Inner is much easier, have a look at recent threads regarding hub puller/cv joints etc.......... :sad:
Offline stainesy
« Reply #6 on: 25 August 2011, 10:47 »
My inner cv boot was gone so instead of faffy about getting a new boot and haviing to take cv joint off drivrshaft and putting it all back together and back on the car I just bought a full driveshaft including fitted cv joint on ebay for £20 lol.
Just had to unbolt from transmision flange and knock other end out of hub and just swap them over.
Cost about the same as a boot kit and I now have spares lol.
Offline Dan_GTi8v
« Reply #7 on: 25 August 2011, 11:43 »
before I start f**king about with it all how likely is it that its my problem?
Offline stainesy
« Reply #8 on: 25 August 2011, 11:58 »
You sure its your suspension?
When does the sound happen?
Offline Dan_GTi8v
« Reply #9 on: 25 August 2011, 13:35 »
Dunno what else it could be, it does it when rocking the front and when driving slowly. could happen when going faster but I cant hear it
