Author Topic: noise from suspension, what to try next  (Read 1942 times)
Offline stainesy
Re: noise from suspension, what to try next
« Reply #10 on: 25 August 2011, 13:41 »
I have exactly the same sound but I thought my coilover just needed greasing between the coil and helper spring. But if you have it aswell without coilys maybe I'm wrong with mine then.
Hhhhhhhhmmmmmmmm
Offline Bellend
« Reply #11 on: 26 August 2011, 00:36 »
After doing this I came to the conclusion the gearbox was knocking at low speeds.  :undecided:
Where all my moneys went.
Offline Dan_GTi8v
« Reply #12 on: 26 August 2011, 14:11 »
its deffinatly not my gearbox, i did think this but on investigation its deffinatly coming romthe wheels/suspension. it does it if I rock the front even with the engine off, I think next thing to try is a new ARB.
It could even be something to do with the brakes. it does seem to be a bit better after changing the wishbones, balljoints and top mounts so could be a combination of things
Offline tweed
« Reply #13 on: 26 August 2011, 14:19 »
check your arb mounts. in fact check all the rubber bushings, good chance one is fcuked.
also get a friend to rock the car while you hunt done where the sound is coming from. bonnet up obviously
