Author Topic: Anyone got the time - ing?  (Read 915 times)
Offline Seanl
« on: 26 July 2011, 18:07 »
Ok so fitted my cambelt today, all seemed to go fine and did seem pretty easy tbh, but cant help feeling a bit anxious as the whether its timed correctly. Cam, crank, intermediate pulley, and dizzy lined up, and checked again after turning it over by hand a couple of times. A few people have suggested using the flywheel mark, but my gearbox isnt on atm so didnt bother with that. Have I fecked up by not using that? Also if its a tooth or 2 out, will I be in the sh!te, or will it go into safe mode? And how can it be half a tooth out?  :huh:
Cheers fellas!  :smiley:
Offline dragongreengolfgti
  • my golf gti mk3
Re: Anyone got the time - ing?
« Reply #1 on: 26 July 2011, 18:16 »
should be fine if you can crank it by hand without hearing or feeling it go tight then your safe if your a tooth out it will definately be in safe mode and wont rev over 5k most likely in that case its the dizzie timing  :smiley:
Offline murraymint
« Reply #2 on: 26 July 2011, 18:25 »
dont hold me to this but i read some were that people had problems with the timing being 1 tooth out and there car would stall wen they came to a stop, this should surely mean that being 1 tooth out isnt goin to kill the engine???
josh
Offline Seanl
« Reply #3 on: 27 July 2011, 08:54 »
Cheers team! as said, engine is out of the car still so will find out when it goes in, in a couple of weeks but fingers crossed. I can handle safe mode, and stalling, but not a rod through the block after everything I have done up til now! :sick:
Offline freezaburn
« Reply #4 on: 27 July 2011, 13:03 »
Search for Free Golf Mk3 workshop manuals" from Teutonic_Tamer ! and look under the Ignition Timing section.
http://www.golfgtiforum.co.uk/index.php?topic=54388.0
Note: Links are NOT broken. You must right-click and select "Save As"...
