Author Topic: Alarm LED stays on then flashes? Now fixed. Siren replaced.  (Read 53007 times)
Offline Snoopy
  • Moderator
  • Geoff.
Im at work so don't have a manual handy.
I think my alarm LED has changed the way it acts.
Could someone have a look in the manual to tell me whats happening please.
It seems to
3 quick Flashes
Stays on fully for about 5 seconds
Then starts to flash.
Im sure it only quick flashed then went to normal flashes before.  :undecided:
« Last Edit: 03 August 2011, 18:14 by Snoopy »
Garage:
35+ years of GTI ownership.
Offline Snoopy
  • Moderator
  • Geoff.
http://www.golfgtiforum.co.uk/index.php?topic=175432.0
That's normal snoopy, exactly what mine does, 4-5 quick flashes and then steady every 2 seconds give or take :smiley:
Great something else gone wrong by the look of it.
This cars jinxed from the start  :sad:
« Last Edit: 22 July 2011, 12:30 by Snoopy »
Garage:
Offline p3asa
I take it the amount flashes signifies something?
Offline Snoopy
  • Moderator
  • Geoff.
1-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH14---    Serial number:
   Coding: 0403000C18070060
   Shop #: WSC 01357 011 00200
   VCID: E7D62531AFFD
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B600D092B0003680F06EC90220081340800
   VCID: 78F4F64D7243
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_VW36.rod
   VCID: 7DFAE7595D61
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180A3E9025F1C0448800803400092443550088732D8960648000200000
   VCID: 32600465D4BF
   Part No: 1K2 955 119 F
   Component: Wischer 19011  21  0512
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 250110 05  54  0402
   Coding: 0330AD
   Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Part No: 1K8 951 605
   Component: LIN BACKUP HO  H10 9003
1 Fault Found:
01134 - Alarm Horn (H12)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 7523 km
                    Time Indication: 0
                    Date: 2016.14.19
                    Time: 08:06:44
             Freeze Frame:
                        Term 15 Off
                    Voltage: 14.05 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA34V4V
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 3B7E294103F5
   Driver's Airbag Crash Sensor:
   Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME1534144FZZZU
   Passenger Side Airbag Crash Sensor:
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME3167444EZZZ.
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME0E354A00ZZZR
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME0E004844ZZZQ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           056 0111
   Coding: 0000502
   VCID: 78F4F64D7243
   Part No: 5K0 959 542
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 D    HW: 5K6 920 970 D
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 470F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 356A3F7925D1
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 220110F2001754
   Coding: E9817F06000212000003
   VCID: 69D2A30939E9
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD05C05BCEF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667755703
   Coding: 010000
   VCID: 2648E835E877
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2140
   Coding: 0000692
   VCID: 336E01612BA5
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 31620B69D1B9
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 32600465D4BF
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1443164
   VCID: 346C027D2EAB
   Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8011304
   Coding: 0100040004
   VCID: 65CAAF39D5F1
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 346C027D2EAB
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356A3F7925D1
End   ---------------------------------------------------------------------
Garage:
Offline Snoopy
  • Moderator
  • Geoff.
My front passennger window had a hickup the other day and the auto up and down did not work im guessing that one of the faults?
Just tested THE ALARM and my alarm siren does not work anymore. I wonder were its located?  :angry:
« Last Edit: 23 July 2011, 14:05 by Snoopy »
Garage:
Offline The Doc
  • E63s Estate - Vito Sport
IMHO
Window fault as per the hiccup
When you say horn do you mean the alarm horn / siren or the cars main horn?
If it's the alarm horn I'm sure that if you locate it and unplug it then the cars main horn should take over ( this is based on theory and not tested )
Good luck mate and keep your chin up  :wink:
Offline Keithuk
Geoff.
EOBD II Error Code: 01134
Fault Location:
Alarm Horn (H12)
Possible Cause:
Anti-Theft Alarm sporadically triggered.
Fuse(s) faulty.
Wiring and/or Connector(s) from/to Alarm Horn (H12) faulty.
Possible Solutions:
Check Fuse(s).
Check Wiring and/or Connector(s) from/to Alarm Horn (H12).
Check/Replace Alarm Horn (H12).
EOBD II Error Code: 00933
Fault Location:
Electric Window Motor; Passenger Side (V148): No or Incorrect Basic Setting / Adaptation
Possible Cause:
Window Automatic Run not working.
Pinch Protection limited.
Automatic Run & Pinch Protection not adapted.
Possible Solutions:
Adapt Automatic Run & Pinch Protection (see Special Notes).
Special Notes:
Pinch Protection Adaptation.
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic.
As taken from my Free EOBD II Error Codes Software
A trip to the dealer?
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Snoopy
  • Moderator
  • Geoff.
The Doc
Door window was odd. It happened last Saturday as i was reversing off the 4 post ramp. I put the window down but it did not want to auto up so i did it up and down about 10 times from both passenger and drivers door to try and get it to work. Simple did not and i put it down to the mirror been foldeded and it been a quirt especially when it worked the next morning.
Alarm horn.
Its the alarm horn not working. To test it I sat in the car, set the alarm and waited for the alarm to arm. I then waved my arms about. Nice flashing hazard lights but no siren/horn  :cry:
It use to work as i have tried it in the past so i knew what it sounded like if i ever heard an alarm go off.
I only notice the difference in the flashing of the LED this morning and so i would suspect it was fine until today.
Keith
I just want to check my waxoyl from a year ago has not upset the alarm horn first (It should not have). Or they may try and bill me for it you know what dealers are like!  :embarassed:
Is the siren that metal box thing in the drivers wheel arch?
« Last Edit: 22 July 2011, 16:59 by Snoopy »
Garage:
Offline Keithuk
There is a metal box SENSORED for security reasons   i noticed when I waxoyl mine. I'm looking at ETKA and it show 2 makes of siren Bosch and Cobra but it doesn't show where they are located.
Electronic siren Bosch >> 05/12/2010 - 1K0 951 605 C - £114.72
Electronic siren Cobra >> 05/12/2010 - 1K8 951 605 A - £114.72 dropped on 01/03/2011 for 1K8 951 605 B - £110.28
In the same picture it shows the ultrasound unit and a horn whether is uses an horn as well but it doesn't show a part number for the horn?
« Last Edit: 23 July 2011, 13:58 by Snoopy »
Offline The Doc
Ok, is your window all good now?
I'll try to find my horn ( :grin:)
