Author Topic: Alarm LED stays on then flashes? Now fixed. Siren replaced.  (Read 53014 times)
Offline Snoopy
  • Moderator
  • Geoff.
The window seems to work ok now. Just wonder for how long.
Keith thanks for the info.
SENSORED for security reasons
All that heavy rain this past week may have killed my alarm siren.  :cry:
« Last Edit: 23 July 2011, 14:06 by Snoopy »
Garage:
35+ years of GTI ownership.
Offline mike.
Looks like the right place Geoff, here is some info if it helps any.
SENSORED for security reasons.
« Last Edit: 23 July 2011, 13:57 by Snoopy »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Snoopy
  • Moderator
  • Geoff.
Thanks Mike.
For security reason im sure everyone is worried about i will remove this thread once its sorted.
Anyone know what fuse it is as i should really check that first  :grin:
The alarm actually works except i have no sound. :grin:
« Last Edit: 23 July 2011, 14:07 by Snoopy »
Garage:
Offline Buck
  • Das Auto
Re: Alarm LED stays on. SIREN not work, Fuse location?
« Reply #13 on: 22 July 2011, 18:56 »
Geoff
This is exactly what happened to my alarm - replaced under warranty. Only downside is that there are two makes of alarm and they had to order mine in.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #14 on: 22 July 2011, 19:09 »
^Thanks.
Im going to take a quick look this weekend just to make sure its not my fault (should not be as waxoyl was a year and a half ago now but best to check.
Then i think its time to make my list of issues and visit the dealer again to get the alarm siren looked at first then,
+ the squeeks(door rubbers & catches)
+ rattles (3 of the door panels loose near window cause rattles, sunroofs rattle foams gone awol, dash speedo area rattle, sunvisor mirror cover rattle, rear hatch rattle)
+ rear passenger side suspension thump
+ engine hesitant at 30mph 3rd gear when i put my foot down (~2500rpm to 3500rpm)
+ waste gate rod rattle at 2500-3000rpm
+ drivers seat bolster premature ware since ~ 2000 miles
+ strange beep beep click/clunk from engine bay every time i turn the car off and get out.
+ rear washer dribble after use.
+ that passenger window blip it had
+ Paint issues (lack of coverage and a couple of issues),
+ Foam in arches issues, (open cell and soke up water)
+ Xenons seam to have a dead spot in the beam
+ heater that does not seem to regulate temp very well, seem to like to freeze me sometimes.
+ more i have probably forgot about. :grin:
Its a bit worrying now i know what the alarm LED ment. As going by the miles i know its been like this since 8am Wednesday morning and its been parked in a ruff part of the city most this week in ear shot but not eye line. I would have never known if something had happened.
« Last Edit: 23 July 2011, 18:35 by Snoopy »
Garage:
Offline Buck
  • Das Auto
« Reply #15 on: 22 July 2011, 19:12 »
I know what you mean
I only found out that mine wasn't working when Darren scanned my car with VCDS when he set up my RNS 510
Might be worth everyone checking that theirs works OK - easy enough check and could save hassle down the line.
Offline mike.
« Reply #16 on: 22 July 2011, 19:22 »
Sensored for security reasons
I think this diagram is for LHD so you may have to reverse the way you look at it, eg. Fuse 1 is top right
« Last Edit: 23 July 2011, 14:10 by Snoopy »
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #17 on: 22 July 2011, 19:25 »
Thanks again Mike  :smiley:
Sorry to be a pain as you have been more than helpful and its much apreciated, but do you have a list of what fuse is what for future reference you could post up when you have a few minutes as i think it would be very useful to all.
Thanks
Geoff.
« Last Edit: 22 July 2011, 19:27 by Snoopy »
Garage:
Offline mike.
« Reply #18 on: 22 July 2011, 19:39 »
Cars from Novemember 2009
F1 - Fuse 1 on fuse holder C -SC1- 10 A
         16-pin connector -T16- Diagnostic connection 15a
          Switch and instrument illumination regulator -E20-
          Air mass meter -G70-
          Auxiliary heater operation relay -J485-
          Electronically controlled damping control unit -J250-
          Headlight range control unit -J431-
          Heater element for crankcase breather -N79-
          Left headlight range control motor -V48-
          Right headlight range control motor -V49-
          Adaptive cruise control unit -J428-
          Headlight range control regulator -E102-
          Brake light switch -F-
          Park assist steering control unit -J791-
          Actuator for structure-borne sound -R214-3
          Voltage stabiliser -J532-5
F2 - Fuse 2 on fuse holder C -SC2- 10 A
          Light switch -E1- 15a
          ABS control unit -J104-
          Control unit in dash panel insert -J285-
          Trailer detector control unit -J345-
          Power steering control unit -J500-
          Data bus diagnostic interface -J533-
          Fuel pump control unit -J538-
          Voltage stabiliser -J532-2
          Selector lever sensors control unit -J587-
          Fuel pump relay -J17-1
          Engine control unit -J623-4
          Driving program button -E598-3
          Starter relay 1 -J906-2
          Starter relay 2 -J907-2
          Mechatronic unit for dual clutch gearbox -J743-
          All-wheel drive control unit -J492-
F3 - Fuse 3 on fuse holder C -SC3- 5 A
      Airbag control unit -J234- 15a
F4 - Fuse 4 on fuse holder C -SC4- 5 A
         High-pressure sender -G65- 15a
          Oil level and oil temperature sender -G266-
          Seat occupied recognition control unit -J706-
          Automatic anti-dazzle interior mirror -Y7-
          Air quality sensor -G238-
          Reversing light switch -F4-
          TCS and ESP button -E256-
          Heater/heat output switch -E16-
          Garage door opener button 1 -E392-
         Tyre pressure monitor display button -E492-
         Anti-dazzle interior mirror button -E386-
          Air conditioning system delay relay -J70-
          Start/Stop operation button -E693-2
F5 - Fuse 5 on fuse holder C -SC5- 10 A
      Control unit for cornering light and headlight range control -J745- right 15a
F6 - Fuse 6 on fuse holder C -SC6- 10 A
      Control unit for cornering light and headlight range control -J745- left -
F7 - Fuse 7 on fuse holder C -SC7- - - Not assigned -
F8 - Fuse 8 on fuse holder C -SC8- - - Not assigned -
F9 - Fuse 9 on fuse holder C -SC9- - - Not assigned -
F10 - Fuse 10 on fuse holder C -SC10- - - Not assigned -
F11 - Fuse 11 on fuse holder C -SC11- - - Not assigned -
F12 - Fuse 12 on fuse holder C -SC12- 10
         Driver door control unit -J386- Central locking 30a
          Front passenger door control unit -J387- Central locking
F13 - Fuse 13 on fuse holder C -SC13- 10 A
         Light switch -E1-
         Rain and light sensor -G397-
         Heated rear window relay -J9-
         Fog light switch -E7-
         Magnetic field sender for compass -G197-
F14 - Fuse 14 on fuse holder C -SC14- 10 A
        Climatronic control unit -J255- 30a
         Air conditioning system control unit -J301-
          Automatic gearbox control unit -J217-
         Tiptronic switch -F189-
          Remote control receiver for auxiliary coolant heater -R149-
          Onboard supply control unit -J519-
F15 - Fuse 15 on fuse holder C -SC15- 20 A
         Rear left door control unit -J388- Central locking
       - Rear right door control unit -J389- Central locking 30a
          Rear lid handle release button -E234- 30a
F16 - Fuse 16 on fuse holder C -SC16- 10 A
        Reversing camera -R189-
F17 - Fuse 17 on fuse holder C -SC17- 10 A
         Alarm horn -H12- 30a
         Interior monitor send and receive module 1 -G303-
         Interior monitor send and receive module 2 -G305-
         Vehicle inclination sender -G384-
          Dual tone horn relay -J4-
F18 - Fuse 18 on fuse holder C -SC18- - - Not assigned -
F19 - Fuse 18 on fuse holder C -SC19- 5 A
         Special vehicle control unit -J608- 30a
          Engine speed governor control unit -J542-
F20 - Fuse 20 on fuse holder C -SC20- - - Not assigned -
F21 - Fuse 21 on fuse holder C -SC21- - - Not assigned -
F22 - Fuse 22 on fuse holder C -SC22- 40 A
        Fresh air blower control unit -J126- 30a
F23 - Fuse 23 on fuse holder C -SC23- 30 A
          Driver door control unit -J386- Window regulator 30a
          Front passenger door control unit -J387- Window regulator
F24 - Fuse 24 on fuse holder C -SC24- 20 A
        Onboard supply control unit -J519- 30a
F25 - Fuse 25 on fuse holder C -SC25- 25 A
        Heated rear window -Z1- 30a
          Fresh air blower relay -J13-
F26 - Fuse 26 on fuse holder C -SC26- 30 A
        Rear left door control unit -J388- Window regulator 30a
         Rear right door control unit -J389- Window regulator
F27 - Fuse 27 on fuse holder C -SC27- 15 A
        Fuel pump control unit -J538- 30a
         Fuel supply relay -J643-
         Relay for supplementary fuel pump -J832-
F28 - Fuse 28 on fuse holder C -SC28- 15 A
          Radio -R-2 30a
          TV tuner -R78-2
          Control unit with display for radio and navigation -J503-2
F29 - Fuse 29 on fuse holder C -SC29- - - Not assigned -
F30 - Fuse 30 on fuse holder C -SC30- 20 A
        Automatic gearbox control unit -J217- 30a
F31 - Fuse 31 on fuse holder C -SC31- 20 A
        Vacuum pump for brakes -V192- 30a
F32 - Fuse 32 on fuse holder C -SC32- 30 A
      DC/AC converter with socket, 12 V - 230 V -U13- 30a
      10 A   Special vehicle control unit -J608-
F33 - Fuse 33 on fuse holder C -SC33- 25 A
        Sliding sunroof adjustment control unit -J245- 30a
F34 - Fuse 34 on fuse holder C -SC34- 15 A
        Driver seat lumbar support adjustment switch -E176- 30a
         Front passenger seat lumbar support adjustment switch -E177-
F35 - Fuse 35 on fuse holder C -SC35- 10 A
        Electronically controlled damping control unit -J250- 30a
F36 - Fuse 36 on fuse holder C -SC36- 20 A
        Headlight washer system relay -J39- 30a
          Headlight washer system pump -V11-
F37 - Fuse 37 on fuse holder C -SC37- 30 A
       Heated front seats control unit -J774- 30a
F38 - Fuse 38 on fuse holder C -SC38- - - Not assigned -
F39 - Fuse 39 on fuse holder C -SC39- - - Not assigned -
F40 - Fuse 40 on fuse holder C -SC40- 40 A
        Air conditioning system control unit -J301- 75a
F41 - Fuse 41 on fuse holder C -SC41- 15 A
        Rear window wiper motor -V12- 75a
F42 - Fuse 14 on fuse holder C -SC42- 20 A
        Blocking diode 2 -J811- 75a
         Cigarette lighter -U1-
         12 V socket -U5-
F43 - Fuse 43 on fuse holder C -SC43- 15 A
        Trailer detector control unit -J345- 30a
F44 - Fuse 44 on fuse holder C -SC44- 20 A
F45 - Fuse 45 on fuse holder C -SC45- 15 A
F46 - Fuse 46 on fuse holder C -SC46- - - Not assigned -
F47 - Fuse 47 on fuse holder C -SC47- 5 A
        Control unit in dash panel insert -J285-2 30a
F48 - Fuse 48 on fuse holder C -SC48- 10 A
        Magnetic field sender for compass -G197-2
        - Mobile telephone operating electronics control unit -J412-2 30a
F49 - Fuse 49 on fuse holder C -SC49- - - Not assigned
Offline Hartside
Great info, but probably time to remove from the forum away from the eyes of those that would do bad things. The fuse location in particular is too much info for them
Carbon Grey 5dr GTI
