Author Topic: MK 3 GTI Ignition Trouble Please Help  (Read 1618 times)
Offline xblade
« on: 20 July 2011, 16:51 »
Ive got a mk 3 gti 2.0l had a problem with my starter motor and coil pack i have renewed them and im still not getting a spark. there used to be an immobiliser on it but that hs been removed properly. Has anyone got any ideas on what it could be thats causeing this problem.
Thanks
Offline javalin
Re: MK 3 GTI Ignition Trouble Please Help
« Reply #1 on: 20 July 2011, 19:13 »
crank sensor, relay or fuse.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline xblade
« Reply #2 on: 20 July 2011, 19:25 »
cheers mate i know its sounds mad which relay and fuse is it because ive been trying tofind out but aint much on the internet
Offline javalin
« Reply #3 on: 20 July 2011, 19:34 »
lots of info on here.
relay 30 and have a look on the maintenance section for the fuse list
James
Offline xblade
« Reply #4 on: 20 July 2011, 20:44 »
thanks for that found the relay 30 going to replace soon all the fuses seem fine im a bit of a novice when it comes to cars but knw a lil bit.. if it aint the relay whats the crank sensor never heard of one of them before.....
Offline javalin
« Reply #5 on: 20 July 2011, 22:28 »
Don't bother with the fuses - if the work, they work.
Crank sensor tells the ECU that the crank has rotated, so it can generate spark timing, etc.   No signal = no spark.
on the 8v its under the oil filter.   Typical fault is burn't away wiring from hot engine & oil leaks etc.
Are you getting a spark on the king lead?
James
Offline dansmk3
  • FULL TIME JUNGLIST
« Reply #6 on: 20 July 2011, 23:35 »
even though its a new coil pack, this one could also be knacked!! get a volt meter on the main lead from the pack to the dizzy and you will know if it works
Offline javalin
« Reply #7 on: 21 July 2011, 08:09 »
and electrocute yourself in the process.... :-(  The coil pack will be putting out > 40,000 volts.
Offline dansmk3
« Reply #8 on: 21 July 2011, 11:39 »
exactly you WILL know!!  :laugh:
sorry, reading that back it was stupid and being rediculously tired and posting does not work  :grin:
Offline javalin
« Reply #9 on: 21 July 2011, 12:29 »
I don't think hospitallizing the OP will really help his car problem though.
