Author Topic: Toad AI606 Extra LED??  (Read 3105 times)
Offline sharki786
  • GOT BOOST??
« on: 16 July 2011, 17:07 »
i just got a LED for a Clifford Alarm (G5 Thinks), I want to know what is the output voltage from the toad unit for the LED? the Clifford LED is 3 volts
LINK: >>> http://cgi.ebay.co.uk/Clifford-G5-Blue-Car-Alarm-LED-/290434425016?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439f3da0b8
any help would be greaful
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: Toad AI606 Extra LED??
« Reply #1 on: 17 July 2011, 18:52 »
anyone?  :undecided:
*****MK4 GTI T*****
Offline Gti Gerbil
« Reply #2 on: 17 July 2011, 19:08 »
no idea what it is,
but if you already got the toad fitted i would pull the led out and check it with my multimeter to see what voltage it was running,
most are 12v tho
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 17 July 2011, 22:26 »
found out from MR TOAD, that the voltage depends on what mode the alarms in (4v-12v) i think thats what he said. so im in middle of soldering a 12v resistor to the + side.
*****MK4 GTI T*****
Offline shepsie
« Reply #4 on: 18 July 2011, 21:21 »
The toad AI606 comes with an armed output that puls to ground when you arm the alarm that u can use for an LED get 1 from Maplins and ask em for a suitable resistor so it doesn't burn out, they do them in just about every colour, and if i were u i'd go for a wide angle LED.
All you do is put 12v feed to one side of the led and conect the other side to the alarm.
Offline troublestarter
« Reply #5 on: 19 July 2011, 20:33 »
all toad and clifford leds are 2 volt you can make a 2 volt led work with the addition of a resistor but i cant'think off hand what value the resistor needs to be
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 03 August 2011, 23:51 »
sorted it, got a 12v flashing blue LED from ebay, connected it up to the LED wire from the unit and a constant live feed and presto farkin bright!! :cool:
*****MK4 GTI T*****
