Author Topic: Engine light after installing 007p  (Read 2782 times)
Offline jnufcuk
« on: 12 July 2011, 15:51 »
Hi all the engine light came on when i was driving the other day. I thought it meant it was due a service? I have replaced, pollen filter, oil etc so would i be right in thinking i should just clear it as i only have the 17705 code iirc (the one that everyone gets :wink:)
The car is running fine but the same thing happened on my old 2.0 and it tied in with the service ??
thanks :afro:
Offline Ant1981
  • Feed me, prod me
Re: Engine light after installing 007p
« Reply #1 on: 12 July 2011, 16:01 »
Usually a seperate warning for service, the orange engine light is probably your code.
'09 Kawasaki Ninja ZX-6R
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 12 July 2011, 17:22 »
yep the word SERVICE and a beep should appear on dash no other lights
Offline jnufcuk
« Reply #3 on: 12 July 2011, 17:25 »
Just scanned it again and got 17544?
Offline Rhyso
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 12 July 2011, 17:34 »
17544 - Fuel Trim: Bank 1 (Add): System too Lean
This means while the car it on idel the fuel system is running lean, the fuel will be running open loop from the maf readings and being trimmed by the closed loop system of the lambda sensor, which means you have a air leak of some kine somewhere.
 If you can check blocks 32 you can see how bad in is in a %.
 01455 617233
Offline jnufcuk
« Reply #6 on: 12 July 2011, 17:35 »
Cheers ryhso do you think it could be because of this split hose?
http://www.golfgtiforum.co.uk/index.php?topic=199562.0
I've taped it up but need to buy some new ones maybe that Might fix it? Can I delete the light by any chnance or is it betterto keep it on?
« Last Edit: 12 July 2011, 17:54 by jnufcuk »
Offline jnufcuk
« Reply #7 on: 12 July 2011, 17:58 »
Cheers rtech, I did have a split hose I posted the link above. :smiley: I only have a cheap £20 code reader so whatdo you Mean by block 32?  :undecided:
Cheers guys
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 12 July 2011, 20:20 »
I've got a shareware version of VAG COM, can that read blocks?
Offline RTechUK
« Reply #9 on: 12 July 2011, 20:25 »
Cheers guys
Yer that can cause the add fuel trim fault code. Catch can mod needed me thinks :-)
 01455 617233
