Author Topic: GTi MK2 E reg leaking water  (Read 5837 times)
Offline mk2bal
Re: GTi MK2 E reg leaking water
« Reply #20 on: 12 July 2011, 21:02 »
I meant the cylinder bit of the gasket by the way,as in leaking from coolant 'hole/ring' in gasket into cylinder 'hole/ring' bit in gasket
Offline Ant1981
  • Feed me, prod me
« Reply #21 on: 12 July 2011, 21:04 »
I did give you an answer for why it couldn't given his symptoms.
MAC you off? Is that a serious answer?  :shocked:
'09 Kawasaki Ninja ZX-6R
Offline mwep201081
« Reply #22 on: 12 July 2011, 21:14 »
Burt matrix is a sound shout if you can see no visible leaks.
Check the passenger foot well for dampness.
Offline Ant1981
  • Feed me, prod me
« Reply #23 on: 12 July 2011, 21:19 »
No its not. If the matrix was leaking you would have a visible leak. Wet carpet passenger or driver side, that would be visible.
Offline mwep201081
« Reply #24 on: 12 July 2011, 21:23 »
Only visible if you are inside the car looking for a leak......
Most would expect a coolant leak to manifest itself from the outside of the car.....
Just an idea but instead of trying to pick an argument with everyone on this new-comers thread, why not have a go at showing them how helpful we can be.....
Offline Ant1981
  • Feed me, prod me
« Reply #25 on: 12 July 2011, 21:32 »
Well I've not seen anyone pick arguments. But I've given answers from my own experience so that I can help the OP. If someone gives wrong information or feels as though they're not.being listened to, they shouldn't see it as a cue for an argument.
Offline mwep201081
« Reply #26 on: 12 July 2011, 21:34 »
I agree.... :rolleyes:
Offline theclash
« Reply #27 on: 12 July 2011, 22:07 »
dear o dear girls  :wink:
Offline aineriddick
« Reply #28 on: 13 July 2011, 11:05 »
Thanks for all the comments, it turns out there is a leak where the water hose meets the radiator, so radiator was empty, it was why the water disappeared
Not so bad news in the end
Offline mk2bal
« Reply #29 on: 13 July 2011, 11:09 »
See the trouble you caused with your bad diagnosis/ fault finding!! Only kidding at least its nothing major :)
