Author Topic: GTi MK2 E reg leaking water  (Read 5866 times)
Offline aineriddick
« on: 11 July 2011, 20:48 »
Can anyone help, I noticed my car needed filling with water very regularly but today when I went to fill it the water disappeared straight away and was empty in about 30 seconds, I put more in and the same happened.  Any ideas what the problem may be.
« Last Edit: 11 July 2011, 20:55 by aineriddick »
Offline The Mighty Elvi
  • I'm better than you today.
Re: GTi MK2 E reg leaking water
« Reply #1 on: 11 July 2011, 20:57 »
Did you see from where the water is leaking from. That would be a big help.
Offline aineriddick
« Reply #2 on: 11 July 2011, 21:26 »
Strangely there doesn't seem to be any water coming out, when I fill it it just empties, I've looked underneath to see where is coming out but nothing that I can see
Offline mk2bal
« Reply #3 on: 11 July 2011, 21:28 »
I reckon the engines drinking it. Engines get thirsty too ya know
Offline aineriddick
« Reply #4 on: 11 July 2011, 21:35 »
Yeah but not litres at a time
Offline mk2bal
« Reply #5 on: 11 July 2011, 22:41 »
Well if it literally drinks it all and doesn't leak a drip out, its either h/g gone quite badly all of a sudden, meaning you'll have loads of h20 in your oil, and could hydro lock the engine soon as you'd  have 8 odd litres of fluid below pistons.. if its defo in the engine its either oil cooler or h/g gone. Does it run any different to normal? Heaters still get hot? Temp guage moving? Fan coming on? Any other signs of over heating? Low power and poor starting?
Offline aineriddick
« Reply #6 on: 12 July 2011, 07:47 »
The car seems to be running fine, drive around all weekend, perfect, last week the 'low on water' light flickered a few times that why I checked it and found it low, drove a lot at weekend so thougth better check it again to find no water, didn't put too much water in realised quickly it wasn't staying so hope didn;'t do too much more damage.  But yeah to answer your question - all seems to be working fine
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 12 July 2011, 08:02 »
It's quite likely
No it won't.
'09 Kawasaki Ninja ZX-6R
Offline theclash
« Reply #8 on: 12 July 2011, 09:09 »
check your oil level on the dipstick as it suddenly gone up........that would point to headgasket
Offline aineriddick
« Reply #9 on: 12 July 2011, 09:19 »
checked the oil, its fine
