Author Topic: Dom's Mk4 Story So Far - it's all over!  (Read 439410 times)
Offline dragongreengolfgti
  • my golf gti mk3
Re: Dom069 - My Mk4 Story So Far, All Spaced Out
« Reply #850 on: 13 March 2012, 15:52 »
looking good  :smiley:
« Reply #851 on: 13 March 2012, 16:46 »
Looks loads better with the spacers :afro:
Offline dom
  • Back in a Mk4
« Reply #852 on: 22 March 2012, 18:27 »
Not updated in a little while, got the correct bolts for the spacers fitted.
I had a pair of Falken 452's fitted to the front last week and have ordered another pair for the rear today. I opted for 215/40/18 instead of 225/40/18 to stop the tyre scrubbing the arch on every little bump :grin:
Other than that I've given it a clean and ordered a load of cleaning products to get it up to scratch before Elsecar.
It doesn't show in this pic but the Votex valance is fooked, paint is cracked where it was repaired after the accident last summer :cry:
Offline scottv6
« Reply #853 on: 22 March 2012, 18:34 »
would look cool with a euro style front bump strip  :smiley: also you thought about retro fitting some headlight washers? ment to be fairly easy
Offline Rhyso
« Reply #854 on: 23 March 2012, 10:24 »
Would require a new bumper, larger washer bottle, the jets, wiring etc etc; I wouldn't have thought it was an easy job  :undecided:
I remember fitting the larger washer bottle to mine and that was a front end off job  :laugh: :laugh:
Offline scottv6
« Reply #855 on: 23 March 2012, 15:38 »
Not that big ju :smiley:st smooth the rub strip fit side indicators. Then cut  the holes that are marked out at back bumperfor the washers mount the washers  fit bigger bottle feeds pipes.  Job dun : :smug:
Offline Rhyso
« Reply #856 on: 23 March 2012, 16:42 »
Crack on then; you've got 90 minutes starting from......NOW!!
 :laugh: :laugh: :laugh: :laugh:
Offline dom
  • Back in a Mk4
« Reply #857 on: 23 March 2012, 17:00 »
If you want to supply the parts & do the work then be my guest :grin:
Offline scottv6
« Reply #858 on: 23 March 2012, 20:18 »
haha, its worth it to look like this,this mk4 looks awsome  :nerd:
Offline Rhyso
« Reply #859 on: 23 March 2012, 20:21 »
All headlight washers do is spray sh!t all over the bonnet and down the wings; I've never seen them be effective at actually cleaning the headlights.  That and you go through a silly amount of washer fluid  :laugh: :laugh:
Anyhoo your 90 minutes is up; it started from when I posted so I'm assuming you've finished  :tongue:
