Author Topic: Dom's Mk4 Story So Far - it's all over!  (Read 439365 times)
Offline DubAndDubber
Re: Dom069 - My Mk4 Story So Far, All Spaced Out
« Reply #830 on: 05 March 2012, 18:16 »
i also want to know what front splitter this is!
Mk5 Golf Gti 06'
Offline daz veedub
  • Operation 1.8t bolf
« Reply #831 on: 05 March 2012, 18:29 »
its a votex front splitter  :smiley:
« Reply #832 on: 05 March 2012, 19:02 »
ah, the ones that are impossible to get hold of!
Mk5 Golf Gti 06'
Offline dom
  • Back in a Mk4
« Reply #833 on: 05 March 2012, 19:49 »
As Daz says it's a votex valance, unfortunately it's taking a bit of a beating at the moment & is starting to get a bit damaged :cry:
Looks great..... what's going on with the tyre in the last shot, looks like half of it's going bald?
It does look a bit strange in that pic, the front tyres are fine though....I even went back outside to check it :grin:
The rears are pretty shot but I've ordered some 215/40/18 Falken 452s to replace them with, they'll then be put on the fronts. Should be on by the end of the week :cool:
Then I've just got to sort out the scrubbing on the rears, I can't even get my little finger between the arch & tyre when the handbrake is off :shocked:
Offline Jack3559
« Reply #834 on: 05 March 2012, 19:52 »
-1.5deg camber courtesy of some shims would do the trick.
Offline dom
  • Back in a Mk4
« Reply #835 on: 05 March 2012, 19:53 »
Good shout, whats the deal with fitting shims? They easy enough to sort?
I don't want to raise it & the spacers are staying on so I guess that's the only option :grin:
Offline daz veedub
« Reply #836 on: 05 March 2012, 20:05 »
theres a topic somewhere on camber shims but cant find the fecker  :undecided:
« Reply #837 on: 05 March 2012, 20:45 »
Why not go for a thinner spacer, camber shims will increase tyre wear.
Also see what your tyre fitter says but the last time I had 2 tyres I was advised to fit them to the rear, not sure why however.
Offline SoundillusioN
« Reply #838 on: 05 March 2012, 21:15 »
Rear tyres with a bit of stretch might help?  :lipsrsealed:
Offline Jack3559
