Author Topic: Dom's Mk4 Story So Far - it's all over!  (Read 439417 times)
Offline Bellend
Re: Dom069 - My Mk4 Story So Far, All Spaced Out
« Reply #840 on: 05 March 2012, 22:58 »
-1.5deg camber courtesy of some shims would do the trick.
Good shout, whats the deal with fitting shims? They easy enough to sort?
I don't want to raise it & the spacers are staying on so I guess that's the only option :grin:
Why not go for a thinner spacer, camber shims will increase tyre wear.
Also see what your tyre fitter says but the last time I had 2 tyres I was advised to fit them to the rear, not sure why however.
All tyre companies now say fit new to the rear. This is because they're less likely to aquaplane. I personally prefer the rear end to go rather then the front but they say it's easier for the back to go in a bend then the front (which for your average driver is true) and it's easier to control apparently.
As I said, I always find it easier to control oversteer BUT if they say it's easier for the back to go then the front, I guess it's true.
Where all my moneys went.
Offline scottv6
« Reply #841 on: 06 March 2012, 18:45 »
looks perfect dom  :cool:
you thought about a s3 front lower strutbrace? think there about £20 ish from audi, well worth the money.
Offline SoundillusioN
« Reply #842 on: 07 March 2012, 10:28 »
Say what?  :rolleyes:
Offline Bellend
« Reply #843 on: 07 March 2012, 17:31 »
http://www.etyres.co.uk/flashmovies/new-tyres-rear-etyres.htm
Offline dom
  • Back in a Mk4
« Reply #844 on: 10 March 2012, 11:59 »
15mm spacers ordered for the fronts :cool:
Offline stow1985
  • 'when im cleaning winders'
« Reply #845 on: 10 March 2012, 22:50 »
Car looks  :cool:
Offline dom
  • Back in a Mk4
« Reply #846 on: 13 March 2012, 14:03 »
Cheers stow :afro:
Spacers arrived this morning, they sent 19mm hex bolts instead of 17mm though :rolleyes:
New ones will be with me tomorrow, I trial fitted one earlier to see how it would sit:
Now running 20mm rears and 15mm fronts, thinner tyres are going on the front tomorrow. The rear coilovers might have to come up a few mm to stop the rears from scrubbing the arches when going over bumps :lipsrsealed:
Offline VR6_Wherry
« Reply #847 on: 13 March 2012, 14:06 »
Look in my thread, that will solve your arch issue! :evil: :grin:
Offline dom
  • Back in a Mk4
« Reply #848 on: 13 March 2012, 14:14 »
I did consider that but it'll be a last resort! I'll trim the plastic inner arch liner but don't fancy attacking metal :grin:
Offline archie837
« Reply #849 on: 13 March 2012, 14:37 »
Wheels have transformed it! Looking really good Dom
Project longterm Airbanger.
PD150 Anni daily
