Poll
Choose one, please.
BBS CK Silver
23 (53.5%)
BBS CS-5 Silver
15 (34.9%)
Cades Bern Hyper Silver
5 (11.6%)
Total Members Voted: 42
Author Topic: To BBS or not to BBS your GTI?  (Read 123344 times)
Offline am1w
Re: To BBS or not to BBS your GTI?
« Reply #150 on: 05 July 2011, 20:49 »
Martin: All is well, as my Silver CKs will be ET 50.  :nerd:
ET will be 49 actually! :nerd:
And it's not BBS that machine them.
Is it just me, or is the thought of machining 5mm off a mounting hub sitting slightly oddly with anyone else?
Is there enough metal to allow it?
Personally, I wouldn't run machined wheels...I'd just buy the wheels that fit properly first time, and know you haven't messed with the manufacturers design.
I was told it is a 2 week wait from BBS to get wheels 'machined' by THEM for the change in ET.
Anyway, that's for mid Sept before the wheels are delivered. I'll certainly consider what you have alerted me to.  :smiley:
You were incorrectly informed. It's the place where you are buying your alloy's from that will send them out to get them machined.
Also the max that can get machined is 5mm.
All i bit ANAL if you ask me but there again you like a bit of bum(so i've heard!) :evil:
Have a nice evening! :grin:
If I did, it certainly would not be your fat ugly arse.  :laugh:
Oh, I forgot ...  :kiss: :kiss:
Offline sundaydriver
« Reply #151 on: 05 July 2011, 20:50 »
If I did it certainly would not be your fat ugly arse.  :laugh:
I aint fat or ugly but i know you like bum! :evil:
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline am1w
« Reply #152 on: 05 July 2011, 20:54 »
Nice to know your physical attributes. But it's still, 'No thanks'.  :kiss:
Offline R32UK
« Reply #153 on: 05 July 2011, 20:55 »
seem you have similar taste in wheels though  :lipsrsealed: :rolleyes:
Offline am1w
« Reply #154 on: 05 July 2011, 21:07 »
............. and knobs.  :drool:
Steven: Have you had your ET changed?
Offline Ess_Three
« Reply #155 on: 05 July 2011, 21:12 »
My fear is that a mounting face has a steel seat (usually) with a set depth below it to allow the use of standard length wheel bolts...if you machine off 5mm from the face, does the bolt extend through the hub far enough to impact on the ABS ring?
There are also issues of bolt torque as the given torque is based on a set clamping length...if you remove 5mm, you shorten this by 5mm and spread the torque over a 5mm shorter distance...does this impact on the bolts elastic limit?
Probably not...but it just seems odd.
I know for a fact that an ET35 CH is a different forging/casting to a ET50 CH...so I find it hard to believe it's all in the machining.
Bear in mind too that they'll be taper seat wheels, not radius seat, so you will ned the matching bolts from BBS, and your locking wheel bolts will not fit....and you'll need to keep 5 of the standard bolts in the boot in case you ever need your spare!
You maybe knew all this...just pointing it out in case.
..but gaining motorcycles.
Offline R32UK
« Reply #156 on: 05 July 2011, 21:15 »
sounds like more hassel than its worth for a set that are likely to slide sideways into a kerb  :lipsrsealed: :laugh:
Offline am1w
« Reply #157 on: 05 July 2011, 21:20 »
Did not know all of it or even half of it!
I was about to PM you and ask about the bolts that would be needed if I had the wheels machined. Your post is most welcome.
It would seem best I leave things alone. I must ask them about the bolt supply from BBS tomorrow.
Thanks a million.
Offline Neil gti
« Reply #158 on: 05 July 2011, 21:28 »
BBS Supply new wheel bolts and locking bolts with the wheels  :smiley:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Ess_Three
« Reply #159 on: 05 July 2011, 21:31 »
Thanks a million.
You should get a BBS fitting kit with them, 20 x bolts and 4 x spigot rings if required...the bolts will be the correct 60 degree taper seat type (no lockin wheel bolts from BBC though)...but will they be the correct length if 5mm is machined off the face? I don't know.
