Poll
Choose one, please.
BBS CK Silver
23 (53.5%)
BBS CS-5 Silver
15 (34.9%)
Cades Bern Hyper Silver
5 (11.6%)
Total Members Voted: 42
Author Topic: To BBS or not to BBS your GTI?  (Read 123351 times)
Offline Ess_Three
Re: To BBS or not to BBS your GTI?
« Reply #160 on: 05 July 2011, 21:33 »
BBS Supply new wheel bolts and locking bolts with the wheels  :smiley:
They do?
I never got locking bolts with my CHs!!
..but gaining motorcycles.
Offline sundaydriver
« Reply #161 on: 05 July 2011, 21:36 »
Steven: Have you had your ET changed?
Nope!
Like Ess_three said it's not worth it. I've never known anyone do it and it can possibly lead to all sort's of problems.
I did look into it but found out that you can't special order a different offset with BBS, it's the BBS stockist that send them out to get machined(Max 5mm)
It's up to you but i'm pretty fussy and mine look fine to me. The BBS stockist said the ET44 gives it a more agressive look! :huh:
Also you get a full fitting kit with the alloy's (spiggot rings,longer bolts and locking wheel nuts) so if you did get them machined your wheel nut's that you have on your car at the moment should fit fine.
Hope my spelling meets your approval!  :wink:
« Last Edit: 05 July 2011, 21:41 by sundaydriver »
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline Ess_Three
« Reply #162 on: 05 July 2011, 22:02 »
Erm...aren't the aftermarket BBS taper seats?
I know my CHs are.
My OEM RXIIs are radius seat...but I was under the impression that ANY BBS wheel that needs a spigot ring uses a taper seat...so the standard wheel bolts will NOT fit fine.
Offline am1w
« Reply #163 on: 05 July 2011, 22:02 »
Nope!
Hope my spelling meets your approval! :grin:
That's great. Thanks. Will leave well alone. The guy at Performance Alloys was adamant not to have it done. Thanks for the heads up or in my case (in your opinion) bums up! :shocked:
Spellcheque not done.  :grin:
« Reply #164 on: 05 July 2011, 22:12 »
If he gets the alloys machined less 5mm the longer wheel bolts supplied with the alloys may not fit that's why i said the one's he has on the car at the moment which are shorter should fit fine.
I also used my VW locking wheel nuts with my BBS CK's, no problems, a little shorter but ok fit.
« Last Edit: 05 July 2011, 22:21 by sundaydriver »
Offline Ess_Three
« Reply #165 on: 05 July 2011, 22:20 »
You are missing the point about the seats...
OEM bolts are RADIUS seat.
Aftermarket BBS are 60 degree TAPER seat.
You cannot use RADIUS seat bolts on TAPER seat wheels or the other way round as it's unsafe and you risk your wheels falling off.
You NEED to match seat type with bolt type...and his OEM bolts have the WRONG profile for aftermarket BBS wheels.
So fit, as it screw in and not hit the ABS ring, yes.
Be safe...no. Utterly wrong...and potentially dangerous.
Offline Ess_Three
« Reply #166 on: 05 July 2011, 22:26 »
So you use a radius seat bolt on a taper seat wheel?
I do hope your other 4 are the correct taper type?
It's a good job one of the wheel bolts are spare and VW didn't decide to fit 5 because they were required. Oh, hang on a minute...
Seriously, get the correct taper seat locking wheel bolts...that is if CKs are taper, like CHs are?
« Reply #167 on: 05 July 2011, 22:26 »
Thanks for explaining, better take out the VW locking wheel nuts and replace them with the ones provided if the CK's are taper.
« Last Edit: 05 July 2011, 22:31 by sundaydriver »
Offline Ess_Three
« Reply #168 on: 05 July 2011, 22:30 »
Thanks for explaining, better take out the VW locking wheel nuts and replace them with the ones provided.
Good man...it's for the best.
You can limp home on 4 bolts, but I would never suggest hammering about on only 4 correct bolts - which is what a missmatch of seats/bolts gives you.
Offline am1w
« Reply #169 on: 05 July 2011, 22:36 »
A big thank you, both of you.
Saved me lots of agro and asking lots of questions.
Very grateful for the excellence of the information.  :smiley:
Glen, missed you.  :smiley:
