Author Topic: VW are taking the shine off my new car - TPMS ordered, but not fitted!  (Read 2880 times)
Offline Daz Auto
  • Other brands of washing powder are available.
Over that last 4 years driving my Mk5 TDI there were two flat tyres. Both on the rear of the car and I did not feel a thing. So both tyres were destroyed, but luckily not the alloys. Because of this - and because I often drive 500 miles in a week - I started checking my tyre pressures every weekend. So for me it was a no brainer to spec the Tyre Pressure Indicator. It should be standard equipment on GTI/GTD. It is only £35 ffs. It could stop a tyre and alloy being destroyed at a cost of nearly £300.
I ordered it. It is on emails with my dealer. My dealer says he ordered it. But it is not fitted. :sad:
I passed little remark when collecting the car as I thought it would be a simple retro fit. Now my dealer is telling me that it is not possible to retro fit the TPMS. He is saying that the ABS control units are different. A quick search here suggests that it is a simple retro fit.  :undecided:
Can a dealer retro fit the Tyre Pressure Indicator?
Thank you for any advice,
Daz Auto
10/8/2017 - GTI Performance, Red,5dr DS
Offline Komenda
Then they need to change the ABS sensors. When you took delivery did agree to take as is, or on the basis they would correct the missing item?
Offline Daz Auto
I said I would like it retro fitted. He said he would check.
AFAIK all that is needed is a reset switch wired from the glove box to the ABS control unit. Then code it with the VCDS. Others here have retro fitted the TPMS.
Don't understand why my dealer is saying it cannot be done.
Offline mike.
It is a simple retrofit but I doubt the dealer would do it as it requires a custom loom and a new connection to the ABS controller.
There is no need for a new ABS controller but it needs to be recoded to enable the function.
Stevep's procedure HERE
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Jimble
Is it definately not fitted? Have you checked your glovebox for the button?
Offline R32UK
If its the same TPMS that was std on the mk5 then its a sh1te feature that isnt worth £1 let alone the £35 vw are charging for it
Offline Daz Auto
Thanks mike. Looks like I will have to fit it myself. Wonder if there is any chance the dealer will enable it for me?
Offline mike.
Mine has worked well for me and caught a couple of slow punctures, so well worth it.
Offline Steve30
  • Ed30 .
Yep I like it too , its also worked for me on 2 occasions £35 well spent if you ask me  :smug:
Tiguan quicker than the Golf
Offline Snoopy
  • Moderator
  • Geoff.
If you don't need the option to reset it (*Thats all the button does) You can enable it via VCDS by ticking a simple box.
Thats how mine was for months till i got round to fitting Steve's button kit.
More info about it, how it works, and a great thread about it worth reading  etc on the below link
http://www.vwwatercooled.org.au/f112/how-retrofit-indirect-tire-pressure-monitoring-5-minutes-7k6-50164.html
« Last Edit: 25 June 2011, 11:37 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
