Author Topic: Smoke & misfire - SORTED!  (Read 10791 times)
Offline NoCrap
« on: 15 June 2011, 22:08 »
Hey all,
I've got a problem with my PD115 (AJM) mkiv that i'm trying to get to the bottom off.
It's been running fine then just over a week ago it all of a sudden started puffing white smoke and misfiring.
I've had it in various pieces to see if i could find anything obvious...
Injector loom appears to have continuity when tested with a metre.
cam belt is in good shape
fuel filter has been changed and primed with diesel treatment
2 x minor coincidences
1 - a minor oil leak from an unknown location which has been happening for a while now
2 - put about 15 litres of V-Power diesel in about a week previous (as it was the only one available)
has anyone else experienced such issues?  i've got a feeling i'm just missing somthing fairly fundemental....
Thanks
« Last Edit: 02 November 2011, 19:51 by NoCrap »
Offline Rhyso
Re: Smoke & misfire
« Reply #1 on: 15 June 2011, 22:10 »
Checked all the boost pipes and clips are intact and in place?
Not got oil mixing with coolant
 :undecided:
Offline NoCrap
Re: Smoke & misfire
« Reply #2 on: 15 June 2011, 22:14 »
Sorry - yes all have been checked...
I'm going to run it up to temperature tomorrow to see what happens
I'll also whip off the expansion tank cap and see if i'm getting any bubbles coming through
Offline Adam
Re: Smoke & misfire
« Reply #3 on: 23 June 2011, 00:42 »
Low fuel pressure or low compression quite possibly.
Down Hill From Here.
Offline Agreeable Slick
  • Unit
Re: Smoke & misfire
« Reply #4 on: 23 June 2011, 12:30 »
White smoke an missfire usually means there is a timing issue. See if you can get a garage to Vagcom it, and adjust the timing slightly.
Offline darren1.8t
  • I HATE FRENCH CARS
Re: Smoke & misfire
« Reply #5 on: 29 June 2011, 20:06 »
i had the same problems mate and after a while it ended up being the dreaded head gsket  :angry:
Offline NoCrap
Re: Smoke & misfire
« Reply #6 on: 02 July 2011, 08:22 »
Compression test done....... cylinder three has zero compression! all the rest are almost spot on 30 bar
Offline Adam
Re: Smoke & misfire
« Reply #7 on: 02 July 2011, 12:36 »
Oh dear. Whip the head off...
Offline NoCrap
Re: Smoke & misfire
« Reply #8 on: 04 July 2011, 17:22 »
Piston three is cracked! arse
Offline Rhyso
Re: Smoke & misfire
« Reply #9 on: 04 July 2011, 17:24 »
 :shocked: :shocked: :shocked:
Any idea what caused that?
