The garage
Mk3 cl automatic bucks into first gear
Topic: Mk3 cl automatic bucks into first gear (Read 3022 times)
Jasikasisback
02 June 2011, 03:31 »
Hi i have a 1996 mkiii cl automatic and it tends to buck and punch itself into first gear sometimes. It will do this most often after a downshift from a full stop. It will do this one or twice and then stop doing this for the rest of the trip. It feeks as if a lot of damage is being dobe to the transmission. Lately it is having trouble upshifting as well not just into first but other gears as well. Since the transmission is sealed i can't check the fluid level.
Any help please?
Shouldn't volkswagen service these auto transmissions for free? I mean the lifetime guarantee should allow for free inspections of the transmission when it is acting up.
Help me out people as i love this car.
Not fair vw that you make a car with a "sealed" transmission.
Can't even check the fluid level.
Wayne
Sir Postalot
Re: Mk3 cl automatic bucks into first gear
02 June 2011, 10:47 »
Specialists can drain and refill the gearbox oil.
Jasikasisback
02 June 2011, 21:42 »
Well and wont that cost more than the car is worth?
AudiA8Quattro
Forum addict
02 June 2011, 21:45 »
You will be able to check the fluid level.
Is it like the Audi where the filler plug is underneath?
Jasikasisback
03 June 2011, 13:37 »
no idea...i think so...it's an 01M box.
Would be a cheap fix to simply top up the fluid..
AudiA8Quattro
Forum addict
03 June 2011, 14:07 »
So its a 1996, what's engine code?
I will try and check over the weekend.
Jasikasisback
Reply #6 on:
03 June 2011, 14:34 »
I'll let you know as I don't have the owner's manual with me...
The car is in the parking lot at work...where do I find the engine code???
(is it that metal plate with all the details of the car???)
AudiA8Quattro
Forum addict
Reply #7 on:
03 June 2011, 14:36 »
There should be a sticker in the boot under the carpet, or try the owners manual.
Jasikasisback
Reply #8 on:
04 June 2011, 14:47 »
1h12f3golf cl eg2 aut
ckx lc6p. Rc 55 kw aam
Any use to you?
AudiA8Quattro
Forum addict
Reply #9 on:
04 June 2011, 15:46 »
Yes that helps.
There is a plug on the top of the sump, remove the cap and pull plug out of filler pipe.
ATF should trickle out of the level hole.
Test it when the gearbox is in park and the fluid is cooler than 30 degrees.
The garage
