Author Topic: 2.0 conversion, what 2.0 bits do I need?  (Read 2971 times)
Offline mr mk2
« on: 24 May 2011, 16:18 »
Could some1 plz send me a checlist of 2.0 parts I will need 4 my conversion eg. Dizzy? Clutch? Cambelt and tensioner? Head gasget? And anything else I need
Thanks in advance
Mr mk2
Offline Sam
  • Sam I am
Re: 2.0 conversion, what 2.0 bits do I need?
« Reply #1 on: 24 May 2011, 17:02 »
As in you are boring your block out to 2.0 or putting another engine in?
Offline mr mk2
« Reply #2 on: 24 May 2011, 17:15 »
Agg 2.0 bottom end
Offline mr mk2
« Reply #3 on: 25 May 2011, 02:41 »
Plz some1 I need help, I wanna try and get everything ready for the weekend but im still not sure what I need
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 25 May 2011, 12:29 »
I think you need to figure it out yourself, to be honest.
There aren't pre-set lists because the parts used vary so much.  You need the donor and the existing alongside each other.  The one gotcha I think you're going to encounter is likely to be the dizzi - you'll want to use the PB unit, so you'll need the adaptor ring, which I think can be supplied by TSR.
Re-use your head, if it's fit.  If it's part of the 'tired old engine' then you really want it skimmed and to be fitted with new valve guides.  I don't think going in from cold at this point that you're likely to come out at the start of next week with a running car.  :undecided:
Offline jmsheahan
« Reply #5 on: 25 May 2011, 22:29 »
Use a 2E dizzy if you can't get hold of an adapter plate. Doing this conversion at the mo.
- Mk3 breather hose setup or blanking plate (TSR do them)
- Mk3 2.0 spark plugs
- Standard clutch is fine but worth replacing if everything is in bits and you don't know the history (in my opinion)
- Engine mounts are probs worth doing while everything is out
Offline mr mk2
« Reply #6 on: 26 May 2011, 09:13 »
Nice 1 thanks m8, hows ur1 comin on?
Offline jmsheahan
« Reply #7 on: 26 May 2011, 09:16 »
Getting there cheers - got the engine in yesterday.
http://www.golfgtiforum.co.uk/index.php?topic=124303.0
Offline mr mk2
« Reply #8 on: 27 May 2011, 17:45 »
The only reason im asking is cuz its a 15 mile round trip 2 my nearest GS and with out a car I dont want to be having to be going 2 and from every 5 mins I just want to order the parts and get cracking
Offline mr mk2
« Reply #9 on: 27 May 2011, 17:47 »
Also who/whats TSF?
