Author Topic: Alloy Trouble  (Read 4810 times)
Offline DubAndDubber
Alloy Trouble
« on: 21 May 2011, 23:08 »
yoo, i recently bought some amg alloys for my mk4. basically i had to order pcd adaptors which was fine.
but i have one big big problem, the bolts wont fit through the hole on the wheel, and obviously i cant get smaller ones because they wont fit the thread on the hub. what do i do! i think i might have a go at drilling them tomorrow to get a bigger diameter in the wheel, then my bolts can fit through. i also need longer bolts. PAIN!
any help would be greatly appreciated!
Mk5 Golf Gti 06'
Offline Thom89
  • Looking for an "Icebreaker"
Re: Alloy Trouble
« Reply #1 on: 22 May 2011, 02:01 »
Have you checked with the spacer supplier the they dont do a different adapter with the correct thread, even if I had to buy new bolts and spacers... I'd rather do that than drill/machine the wheels, check first! measure what size threads are required in the adapters!
Thom
VW BUSH
Re: Alloy Trouble
« Reply #2 on: 22 May 2011, 02:05 »
You would need to have them machined properly, black and decker =  :sick:
Re: Alloy Trouble
« Reply #3 on: 22 May 2011, 02:08 »
lol why cant i do it with a black and decker! that was the plan! nah the adaptors were 150 alone mate im not buying another set! know how much it is roughly to get them machined?
Mk5 Golf Gti 06'
Offline JC
  • Back in the North.
Re: Alloy Trouble
« Reply #4 on: 22 May 2011, 08:27 »
first i was like  :shocked:
 then i was like  :laugh:
 but now i am  :sick:
Offline dazzawest1987
Re: Alloy Trouble
« Reply #5 on: 22 May 2011, 09:19 »
Surely if they sell a set with the correct bolts, you could return the set you got and have the correct ones sent out to you?
Offline JC
Re: Alloy Trouble
« Reply #6 on: 22 May 2011, 09:43 »
merc bolts are smaller than dub, even if fitting onto a passat ( 5x112 same as merc )  people have issues ,
Re: Alloy Trouble
« Reply #7 on: 22 May 2011, 21:41 »
 but now i am  :sick:
proper dont understand that mate, anyways ive had a bit of progress today, drilled the holes in the alloy with a black and decker. i know what youre thinking but it came out bloody good, took my time with it and im pretty chuffed! pardon the pun. now all i need to get is longer bolts which ill be getting tomorrow. ill keep you posted!
Mk5 Golf Gti 06'
Re: Alloy Trouble
« Reply #8 on: 22 May 2011, 21:49 »
You drilled the wheels  :shocked:
Offline Thom89
Re: Alloy Trouble
« Reply #9 on: 22 May 2011, 23:58 »
 but now i am  :sick:
Its simple,
First he was like  :shocked:
Then he was like  :laugh:
But now, he's like :sick:
HTH
Thom
