Author Topic: 280mm brake conversion - confussed!  (Read 10891 times)
Offline sprout99
Re: 280mm brake conversion - confussed!
« Reply #10 on: 12 May 2011, 15:36 »
280's fit in my 15" bbs's ?
are they RA's?? (not big nuts)
I have original fit Ra's and there is only 2mm clearance to calliper.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline dashey
« Reply #11 on: 12 May 2011, 15:57 »
You dont need to drill no holes the g60 are already 4x100
Offline RossyB108
« Reply #12 on: 12 May 2011, 15:58 »
2mm clearance on a 280mm upgrade or standard 256mm?
Offline RossyB108
« Reply #13 on: 12 May 2011, 15:59 »
They aren't G60 discs, they are 280mm VR6 5x100 Corrado disks.
Thanks
Offline dashey
« Reply #14 on: 12 May 2011, 16:00 »
Where the hell did i read g60 then, my apolagies
Offline RossyB108
« Reply #15 on: 12 May 2011, 16:13 »
No worries ;)
Still not really any the wiser.
Any more advise/experience really appreciated.
Offline sprout99
« Reply #16 on: 12 May 2011, 16:20 »
i converted my 256 to 280 but wanted to keep std wheels
Oak green mk2
V50 D5 Sportwagon
Offline RossyB108
« Reply #17 on: 12 May 2011, 16:31 »
Me too!
What's your set up then?
VR6 280mm calipers and carriers + G60 discs?
thanks
Offline sprout99
« Reply #18 on: 12 May 2011, 16:42 »
it was very confusing
you need 280mm carriers from a pre 95 car or hubs are drfferent.
280mm disks - i bought G60 ones from vwspares.co.uk
std 16v pads and used std callipers. You will need to modify the slide pins. The first set i used angle grinder
but then did another set in workshop at work when i got sizes right.
it's about 3mm you need to remove - easy with a lathe.
Oak green mk2
V50 D5 Sportwagon
Offline RossyB108
« Reply #19 on: 12 May 2011, 16:49 »
So why wont the 280mm calipers fit?
I'm sure I've read plenty of posts in the past saying they do fit.
Which part of the alloy do they hit?
