Author Topic: 280mm brake conversion - confussed!  (Read 10890 times)
Offline RossyB108
« on: 12 May 2011, 13:36 »
Hi,
I know there's heaps of stuff in the search on this but after sifting through tones of it I couldn't quite get the answers I needed...
Will a 280mm Corrado VR6 caliper and carrier, pads and disc set up fit my big bumper 16v Golf GTI?
I know the discs are 5x100 so they wont fit, so I'll have to get hold of some 280mm 4x100 G60 discs
Also, will it fit under my BBS RA's?
Thanks!
Re: 280mm brake conversion - confussed!
« Reply #1 on: 12 May 2011, 13:38 »
Nope I believe the offset of the discs is all wrong.
You will need 15" wheels
Offline RossyB108
« Reply #2 on: 12 May 2011, 13:55 »
Oh poo. So the 280mm VR6 Corrado calipers and carriers are different to the pre-96 Mk3 Golf VR6 calipers??
My BBS RA's are 15" - so they should be ok with a 280mm set up?
Thanks
Offline dashey
« Reply #3 on: 12 May 2011, 14:20 »
The corrado discs will go straight on mate i duno if your wheels will take the size only one way to find out i suppose
Offline dashey
« Reply #4 on: 12 May 2011, 14:22 »
With vr6 callipers they are easier to get hold of and basiclly the same as the g60
Offline RossyB108
« Reply #5 on: 12 May 2011, 14:36 »
Will I need to drill new holes in the Corrado 5x100 discs to make them fit my 4x100 hubs?
So it sounds like everything from the Corrado VR6 will fit then (bar me having to drill new holes in the discs)
Great thanks!
Offline sprout99
« Reply #6 on: 12 May 2011, 14:42 »
Thanks
not true. If you want to keep your RA's you'll have to use golf 16v callipers with 280 carriers and modify the slide pins
and use the 16v pads which are thinner
i've got the hybrid set up on mine - carriers came from a mk3 golf.
need to remove 3mm from slides - acess to a  lathe is very helpful
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
« Reply #7 on: 12 May 2011, 14:43 »
Thanks
once all modifed they fill the wheels and stop really well.
Oak green mk2
V50 D5 Sportwagon
Offline emery1990
« Reply #8 on: 12 May 2011, 15:15 »
280's fit in my 15" bbs's ?
Offline RossyB108
« Reply #9 on: 12 May 2011, 15:23 »
Is it the 288mm set up that need grinding back then?
Still confused! :)
I'm hoping it'll all just fit without needing any mods! (Apart from 4x100 holes).
Thanks
