Author Topic: 280mm brake conversion - confussed!  (Read 10890 times)
Offline RossyB108
Re: 280mm brake conversion - confussed!
« Reply #30 on: 24 May 2011, 13:57 »
Just to give an update.
The Corrado V6 280mm carrier and calipers fitted straight on my Golf 16v hubs but do in fact foul the front/spokes of my 15" BBS RA's.  Luckily my 10mm wheel spacers sorted that problem.
The Corrado 280mm discs do not fit though as the offset is out (just as many of you have suggested), so even if I drilled the 4x100 stud pattern it's a no go for the discs.
So I'm going to order a pair of G60 280mm 4x100 discs to go on shortly and I'm all 280'd up!
Thanks everyone
Offline sprout99
« Reply #31 on: 24 May 2011, 13:59 »
Thanks everyone
yup - that's why i used std calliper and modified the slide pins to allow the 16v calliper to fit 280mm carrier
glad you sorted now
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
