Author Topic: Problems with our new family member: 8v MkIII GTi  (Read 4295 times)
Offline GazTheHat
« on: 22 March 2005, 14:16 »
Hi All,
I was going to post the problems in their own threads, but the amount of probs we have, might fill the whole site.? :sad: Before people say we shouldn't of bought it, we got it at a steal, just needs some TLC!!
The wipers. The rear one doesn't work at all. I saw it on once, when faffing with the MFA, but it stopped and i've never got it on since. Also, the front wipers, when off, don't reset, they stop wherever they were when you turn it off. So it's taking timing to get them to sit at the bottom. Is this a simple problem to fix? Something a non-mechanically-minded chap can do?? I've gotta save some dosh, but obviously want it fixed.
What with the fuel leak recently fixed - eyes on fuel guage for a repeat of breakdown, eye's on MFA checking cool info and now eyes on the wipers, i'm not lOOking at the road much!? ?:grin:
Clutch. When i rest my foot on the clutch and when fully depressed, there's a scuffing noise. Someone was telling me it's the clutch release bearings. Is this serious? Worth fixing if it means gearbox out and wot-not??
Changing Panels. 2 doors and the tailgate are rusting, the TG especially bad. Think it's this weather up here in Irn Bru country!! Is it easy enough to change a door and tailgate? Anyone know of a (VW) breakers up near Glasgow?? I need plastics and a few other things as well.....
Electric Sunroof. It only tilts, no slide. I kept faffing with it and managed to get it to slide about 1cm, with continous pushing/prodding the levers. I doubt i'll use it much, what with our weather, but it would be nice to fix. Do i just need a motor from a breakers?? Anyone had to replace one and remember the cost??
Wheel Alignment. I can see a front wheel is off, and the other has dodgy tire tread. Before i shell-out to get this sorted, i just wanted to know, as i'm planning in the near future to change the wheels (hopefully 17"s, currently has 15" OZs), is it worth getting the alignment done now, or waiting for the new wheels and doing it then? If i did it now would it need to be done again with new wheels??
I don't know if this is the associated. But at higher speeds 70+ there's greater vibration noise, coming from the corner with the "out" wheel.
Wheels. I've been reading that on 17's it tramlines quite a lot. The wheels on it are pretty scabby, so i would like to replace. Would it be best on 17's or 16's then?? I don't fancy rolling the arches, but also want to lower it onto them. I don't know if it's been lowered already?? (there's already mods on it......and it doesn't lOOk like a Paris Dakar entry? :smiley: )? Do the Audi TT wheels fit directly on?? I've seen several golfs now with what lOOks like the TT wheels. Any other cars that have the same fitting wheels i could possibly source for a bargain??
Apart from the few problems, and in need of a valet, it's a cracking little car. Quite sporty, (nice to have that nip before 3000, unlike previous turbo'd motors), excellent handling - very positive and little roll. Ooses build quality and feels solid. I can see us keeping this car even when our new car arrives...!!
Thanks in advance for any help/answers, never owned a VW before (well don't know, it's the wifey's? :grin: )
GazTheHat
mowgli
Re: Problems with our new family member: 8v MkIII GTi
« Reply #1 on: 22 March 2005, 15:38 »
The wipers. The rear one doesn't work at all. I saw it on once, when faffing with the MFA, but it stopped and i've never got it on since. Also, the front wipers, when off, don't reset, they stop wherever they were when you turn it off. So it's taking timing to get them to sit at the bottom. Is this a simple problem to fix? Something a non-mechanically-minded chap can do?? I've gotta save some dosh, but obviously want it fixed. - My guess would be a wiring problem in the right hand stalk or the connecting plug??
Clutch. When i rest my foot on the clutch and when fully depressed, there's a scuffing noise. Someone was telling me it's the clutch release bearings. Is this serious? Worth fixing if it means gearbox out and wot-not?? - It sounds like the release bearing to me, worth slapping a new clutch in IRO ?75 from Euro Car Parts.? There is a dedicated link to the Leeds branch on this site.
Changing Panels. 2 doors and the tailgate are rusting, the TG especially bad. Think it's this weather up here in Irn Bru country!! Is it easy enough to change a door and tailgate? Anyone know of a (VW) breakers up near Glasgow?? I need plastics and a few other things as well..... - Can't help on this one sorry.
Electric Sunroof. It only tilts, no slide. I kept faffing with it and managed to get it to slide about 1cm, with continous pushing/prodding the levers. I doubt i'll use it much, what with our weather, but it would be nice to fix. Do i just need a motor from a breakers?? Anyone had to replace one and remember the cost?? - As above sorry.
Wheel Alignment. I can see a front wheel is off, and the other has dodgy tire tread. Before i shell-out to get this sorted, i just wanted to know, as i'm planning in the near future to change the wheels (hopefully 17"s, currently has 15" OZs), is it worth getting the alignment done now, or waiting for the new wheels and doing it then? If i did it now would it need to be done again with new wheels?? - is it definately the alignment thats out?? The comment about "off" got me confused, a worn damper would cause uneven tyre wear as would damaged track control arms etc.
I don't know if this is the associated. But at higher speeds 70+ there's greater vibration noise, coming from the corner with the "out" wheel. - Off balance wheel or possible wheel bearing??
Wheels. I've been reading that on 17's it tramlines quite a lot. The wheels on it are pretty scabby, so i would like to replace. Would it be best on 17's or 16's then?? I don't fancy rolling the arches, but also want to lower it onto them. I don't know if it's been lowered already?? (there's already mods on it......and it doesn't lOOk like a Paris Dakar entry? :smiley: )? Do the Audi TT wheels fit directly on?? I've seen several golfs now with what lOOks like the TT wheels. Any other cars that have the same fitting wheels i could possibly source for a bargain?? - When buying Audi wheels you have to ensure its 100 PCD and the correct offset.? A lot of Audi wheels are 112 PCD and can be made to fit but AFAIK its well expensive.? A cheaper option possibly would be a set of Anniversary wheels which are 16's and will go straight on.
Apart from the few problems, and in need of a valet, it's a cracking little car. Quite sporty, (nice to have that nip before 3000, unlike previous turbo'd motors), excellent handling - very positive and little roll. Ooses build quality and feels solid. I can see us keeping this car even when our new car arrives...!! - I've got one, my fourth Mk3 8v, its not as quick as some but its a very good all rounder.? The boss will have a hoot driving it, my other half has a Seat Ibiza GTi which is a polo with the same engine and gearbox as yours.? It flies, she loves it and has turned into a proper girl racer!
Thanks in advance for any help/answers, never owned a VW before (well don't know, it's the wifey's? :grin: )? Good choice in manufacturer!!
Hope that helps in some way.
Offline cammy
« Reply #2 on: 22 March 2005, 21:03 »
thirs a scrapy next to airport, take paisly cut off <big roundbout left and indust estate on the right>  at the back ...also FALLONT IN AIRDRIE  THEV GOT 3 /3 VW IN ......PAISYY 1  GOT MRK 3  ...  AND 1 OFF SEEDHILL RD ................IF U NEED BETTER DIRECTIONS GET BA CK 2 ME ..IL BE ON 1ST THING IN THE MORNING 9AM SO IL HAVE BETER STREET NAMES .....HOPE THIS HELPS                ...............................
                             CAMMY
Offline AudiA8Quattro
« Reply #3 on: 23 March 2005, 00:26 »
You can get the clutch release bearing changed without removing the gearbox on an 8v  :laugh:
Offline GazTheHat
« Reply #4 on: 23 March 2005, 10:39 »
                             CAMMY
I work in Paisley. I couldn't make head nor tail of your directions :smiley:  If you could let me know the street names and i'll head over at lunchtime. Thanks.
GazTheHat
Offline 8vgti
« Reply #5 on: 23 March 2005, 12:46 »
In relation to your sunroof motor query wouldnt know what a good price would be but seen one for £50 on www.volkswizard.co.uk in parts section and a complete assembly for £80 excl. motor. Any use??
Offline GazTheHat
« Reply #6 on: 23 March 2005, 14:08 »
Thanks for the info. I'll have a shop around. Quite interested to see what the breakers have to offer and a few people are breaking their Golfs, so let's see....  :rolleyes:
Offline GazTheHat
« Reply #7 on: 23 March 2005, 14:11 »
That's good news. I thought it had to come out, by the response from the garage. He said it's best to just leave it, easier and cheaper. So naturally i thought it was a big job. I'll get a quote, see what he says...
Offline cammy
« Reply #8 on: 24 March 2005, 21:37 »
MACKEAN ST   , OFF GREENOCK ROAD .I THINK ..........THERS A VW GARAGE A FEW UNITS UP FROM IT ....MACKEAN ST OR A STREET NEXT TO IT, BUT ITS IN THE BUISNESS PARK  ,  THAT I NO,HOPE THIS HELPS
 :laugh:
Offline mysticman aka polypathetic
« Reply #9 on: 26 March 2005, 09:08 »
how is this possible please explain
regards
jay
