Author Topic: Problems with our new family member: 8v MkIII GTi  (Read 4307 times)
Offline AudiA8Quattro
Re: Problems with our new family member: 8v MkIII GTi
« Reply #10 on: 26 March 2005, 23:20 »
On some golfs the clutch is of reverse type to conventional.
On the reverse type, the pressure plate is bolted directly to the crankshaft flange, the clutch friction disc in the middle, the flywheel fitted last. There is a pushrod that goes through the input shaft of the gearbox,when the clutch pedal is pressed the rod pushes against a packing plate which releases the pressure on the clutch pressure plate, this will release the friction disc from the flywheel and so disconnect the gearbox from the engine.
The release bearing on this type of arrangement is situated at the end of the gearbox, you can remove the end cover to replace it.
Conventional clutches have the flywheel fitted to the crankshaft flange, the friction disc, and the pressure plate fitted last. The release bearing on this type fits on the input shaft of the gearbox.
You can tell which type is fitted by seeing where the cable goes.
All hydraulic clutches, like the mk3 16v and vr6 have the conventional arrangement.
However if you look at mk2 gti 8v/16v and mk3 8v you will see the clutch cable connects to a lever which in turn operates the pushrod, so this lever will connect towards the end of the gearbox.
I hope that helps.
By the way i have fitted both types of clutches, one on a mk2 16v and on a mk3 vr6  :laugh:
Offline GazTheHat
« Reply #11 on: 31 March 2005, 12:50 »
You can get the clutch release bearing changed without removing the gearbox on an 8v  :laugh:
The guy at the garage confirmed the gearbox does have to come off. Is he after more labour charges or can anyone else confirm this? I said just to change the whole clutch kit if the gearbox is off, one less thing to worrry about.
Offline GazTheHat
« Reply #12 on: 31 March 2005, 12:53 »
MACKEAN ST   , OFF GREENOCK ROAD .I THINK ..........THERS A VW GARAGE A FEW UNITS UP FROM IT ....MACKEAN ST OR A STREET NEXT TO IT, BUT ITS IN THE BUISNESS PARK  ,  THAT I NO,HOPE THIS HELPS
 :laugh:
Streetmap couldn't find Mackean St and my A-Z is at home. I'll check that out later, but i think i know where you mean. Failing that it's an excuse to take the car for a drive  :wink:
« Reply #14 on: 01 April 2005, 12:51 »
If the 8v has a cable clutch, which i'm sure it does, then the garage is lying to you.
Offline mr wong
« Reply #15 on: 01 April 2005, 17:58 »
Dont know if this helps at all. but when my car was in (8v) i was told that it was a "self adjusting clutch" .
Offline pinkfloyd
« Reply #16 on: 30 April 2005, 07:37 »
With regards to the wipers if you change the relay (it has 19 printed on it) you should find this works, just done it on my mk3 cab and works a treat now  :grin:
