Author Topic: Tdi Tuning.....  (Read 4326 times)
Offline Rixy
Tdi Tuning.....
« on: 18 April 2011, 21:20 »
Hi peeps, im gonna start the tuning on my mk3 tdi finally. Just wanna clarify a few thing first.....
What boost does the stock setup make? I've fitted the guage, but i cant find a t piece to plumb it into the car yet. Do i Plug the guage into the boost pipe feed comin from the inlet elbow up to the ECU?
Also, i've fitted a tuning box, i've had it for ages but never fitted it as i wasnt sure if it was any good,however its fitted now, and it has made it better for sure.
I have set the adjusment screw on the box at what i think is a safe level, when under full load there is a light haze of smoke, but nothing black, and it goes really well. Also, i can always hear the wastegate opening after about 2k of revs, so is it worth fitting a Manual boost controller so i can hold the boost on a bit?
What is a safe level for boost? I've heard about 18 i safest high boost for the turbo and the engine internals? if this is the case, i'll stick at around 15 so im well below?
cheers for ur input peeps :-)
Re: Tdi Tuning.....
« Reply #1 on: 18 April 2011, 21:54 »
Be carefull with turning the boost up on a manual controller, it could end in tears.
Offline Rixy
Re: Tdi Tuning.....
« Reply #2 on: 18 April 2011, 21:56 »
i know matey, i've done alot of diesel tuning in the past, know what im doing, but just wanna know a bit more about the mk3 setup, as im used to the earlier mk2 GTD setups and the like.
I have just stumbled across the TDI forum though, and found nearly everythin i need on there, so this thread is kinda useless now, lol....
Re: Tdi Tuning.....
« Reply #3 on: 18 April 2011, 21:58 »
I believe TDI110 injectors are an upgrade that is worth doing. :smiley:
The turbo is the limit for boost really
Offline Rixy
Re: Tdi Tuning.....
« Reply #4 on: 18 April 2011, 21:59 »
yup, the .205's are the 110 jobbies, or even the 150bhp T4's .216's :-)
Offline Gash
Re: Tdi Tuning.....
« Reply #5 on: 18 April 2011, 22:39 »
.216 it! i did loads of looking into tuning one these engines and well 2k can get one of these to 250bhp on standard internals :D
Offline lockey
Offline Gash
Re: Tdi Tuning.....
« Reply #7 on: 18 April 2011, 23:27 »
pop them in and a chip will go from 90 bhp to about 110bhp-120 (if your lucky) dont need a remap.
but youl make alot of smoke.. to get rid of that just change the turbo :D
Offline lockey
Re: Tdi Tuning.....
« Reply #8 on: 18 April 2011, 23:31 »
nice what turbos just bolt on though
Offline Jack3559
Re: Tdi Tuning.....
« Reply #9 on: 19 April 2011, 10:18 »
Pics?
