Author Topic: 10mm spacers do i need longer bolts  (Read 5695 times)
Offline rench
« on: 17 March 2011, 22:11 »
ive just got some 10mm and 8mm spacers can i use my original bolts or do i need longer ones?
Offline Toby
  • Car - less
Re: 10mm spacers do i need longer bolts
« Reply #1 on: 17 March 2011, 22:15 »
yes  :wink:
Currently down under
Offline vwfiend
« Reply #2 on: 17 March 2011, 22:17 »
Offline rench
« Reply #3 on: 17 March 2011, 22:18 »
dam it lol was hoping not, do i need longer for the 8mm aswell then?
Offline Toby
  • Car - less
« Reply #4 on: 17 March 2011, 22:21 »
haha i the yes was to he needs longer bolts  :rolleyes: long day n all that.  :sick:
Offline p11jon
« Reply #5 on: 17 March 2011, 22:23 »
you can only use standard bolt on 5mm spacer. if you value you life and dnt wont to turn your car into a boat half way down the road with all the wheels coming off i advise you buy the longer bolts! if you add 10mm spacers take a standard bolt measure the thread and add 10mm to it to compensate for the extra distance it needs to cover through the spacer. JOB DONE.LOCK  :laugh: :laugh: :laugh:
Offline p11jon
« Reply #6 on: 17 March 2011, 22:24 »
yes  :wink:
Fail answer!!!  :laugh:
i think he meant yes you need longer ones not yes they will work to be fair although it may of been better to be more specific i agree :laugh: :laugh: :laugh:
Offline andc1
« Reply #7 on: 17 March 2011, 22:32 »
becareful with 5mm using standard bolts, not much thread left, 3mm tops ive always gone with, 5mm+ should really be hubcentric aswell  :wink:
Offline p11jon
« Reply #8 on: 17 March 2011, 22:44 »
you only lose a couple of turns of the bolt there plenty running standard bolt with 5mm. lots of people do. i believe wazzzer and wayne and that bunch have all advised it in the past me being one of those people and never had a problem mate :wink:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 17 March 2011, 22:48 »
as said just get longer bolts the extra length of the spacer you have.. 10mm so get 10mm longer etc etc
