Author Topic: exhaust probs  (Read 2274 times)
Offline danmusic24
exhaust probs
« on: 05 March 2011, 08:35 »
my exhaust seems to be playing up.the car has lack of power and popping noise coming from middle box but cant see any holes! is it possible that the baffles might of collasped inside the box would this cause running problems?
Offline Luke1981
Re: exhaust probs
« Reply #1 on: 05 March 2011, 13:42 »
The best thing to do is get a vacuum and pressure test done on the exhaust including an emissions test. This will determine if your CAT is working and confirm whether there is any leaks in the exhaust or manifold gasket that you might not be able to see.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Mike87Turbo
Re: exhaust probs
« Reply #2 on: 05 March 2011, 13:56 »
Also if its 'popping' in the exhaust rather than rattling, it may be that its running a bit rough and throwing unburnt fuel into the exhaust?? Would also explain the lack of power anyways!
Let me know what you find, ill be interested to find out what this is  :cool:
Re: exhaust probs
« Reply #3 on: 05 March 2011, 19:53 »
Popping is a sign that it is not running right.  :smiley:
Offline danmusic24
Re: exhaust probs
« Reply #4 on: 06 March 2011, 08:53 »
thanks for that wayne all my problems are solved :grin:
Re: exhaust probs
« Reply #5 on: 06 March 2011, 17:00 »
No worries, have you had it scanned for fault codes.
Offline harlemex
Re: exhaust probs
« Reply #6 on: 06 March 2011, 17:25 »
Wtf???!!  :grin: :grin: :grin:
Offline danmusic24
Re: exhaust probs
« Reply #7 on: 08 March 2011, 07:58 »
ok more help needed! my exhaust has been tested and is fine,had a split hose going from intake manifold to vacum servo(replaced)the car is still hunting and pulls back when accelerating,had rac out and they cant find fault,took it to a garage and they said they did not want anything to do with it(bastards)....got no error codes coming up on vagcom..sounds like a sabaru at the moment..this is really doing my head in!!! any ideas anyone pls :sad:
Offline neil1780
Re: exhaust probs
« Reply #8 on: 08 March 2011, 22:05 »
Have you checked the obvious things mate like plugs and leads dizzy cap?
V6 4MOTION
Offline polo6n222
Re: exhaust probs
« Reply #9 on: 09 March 2011, 12:08 »
maf  have u tryed unpluging it and seeing what happens
