Author Topic: exhaust probs  (Read 2279 times)
Offline Khare
  • The bear that khares
Re: exhaust probs
« Reply #10 on: 09 March 2011, 12:33 »
Coil? It has the ignition amplifier built it, it might be failing. Also the fact that the car holds back under load points towards coil.
Offline danmusic24
Re: exhaust probs
« Reply #11 on: 09 March 2011, 13:57 »
have had a go changing coil as ive always got a couple spare,but no joy...the car seems to run fine when stone cold then after 10mins starts playing up..just got autodata cd so going to start checking sensors and things. :sad:
maf ok
plugs and leads ok
Offline Luke1981
Re: exhaust probs
« Reply #12 on: 09 March 2011, 17:26 »
It might be your air flow sensor that's knackered which could cause your car to run badly.
Let me know how you get on. Good luck
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline danmusic24
Re: exhaust probs
« Reply #13 on: 10 March 2011, 19:04 »
why does the agg(or other engines)need the pipe coming from rocker cover to intake duct? cant you just plug this and leave crank breather pipe in place?....also is the disc on top of rocker cover serviceable,cant seem to get it off,its got tons of crap in it..which i think will not help my running problems..
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: exhaust probs
« Reply #14 on: 10 March 2011, 19:53 »
The breather pipes need to be fitted as it forms part of a closed loop system. Without it fitted running and idle will almost certainly be affected. The flying saucer looking thing on top of the rocker cover cant be taken apart but what ive done in the past is to soak it in petrol for a while to remove all the mayo gunk from inside it.
Offline danmusic24
Re: exhaust probs
« Reply #15 on: 10 March 2011, 19:58 »
yeah that makes sense! mines in a right mess so will give that a go,does it pop out of the rocker cover ok or did you soak it with rocker cover off?
Re: exhaust probs
« Reply #16 on: 10 March 2011, 20:11 »
Yeah you simply disconnect the hoses then remove the breather pressure regulating valve from the top of the rocker cover, on the AGG engines there are two screws holding it down beneath a square plastic plate then carefully pull it from the rocker cover. Be prepared to replace the rubber gasket/ collar around the base though as these can split when removed as they perish with age.
17    037 129 101 G    pressure regulating valve
11    028 103 500    gasket
Offline danmusic24
Re: exhaust probs
« Reply #17 on: 10 March 2011, 20:20 »
top stuff!!! cheers :smiley:
