Author Topic: Cruise contol system  (Read 4850 times)
Offline yosin
« on: 22 February 2011, 13:22 »
jus driving home today for lunch and parking up i notice the light has come up on the sash. had a quick flick through in manual but doesnt tell me too much about it.
firstly how did it come on? and is this a useful thing?
thanks
Offline yosin
Re: Cruise contol system
« Reply #1 on: 22 February 2011, 13:25 »
sorry typing on the phone. i meant the light come up on the dash*
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
« Reply #2 on: 22 February 2011, 14:28 »
If it's the cruise control light (I think it's green IIRC) then when you touch either the brake or clutch it will disappear.
The only way to turn it on is if you flick the 'set' switch on the left hand stalk.
Are you sure it's the cruise control light?
Offline yosin
« Reply #3 on: 22 February 2011, 14:45 »
i am pretty certain this is the cruise control system light. its page 139 in the book. stuck at wk at the moment so will double check it when i finish.
is this a useful thing on the car the so called ccs?
Offline simond65
« Reply #4 on: 22 February 2011, 15:06 »
Yep the Cruise Control light is green on the dash that looks like a mini speedo to look at. The light comes on if the CC is activated by setting the rocker switch over to the left although the speed setting is done via a separate rocker on the same stalk. The light remains on the dash throughout.
So if you've flicked the switch on the left hand stalk that would bring the light on but if you haven't possibly a wiring fault?
Offline Ed30DSG
« Reply #5 on: 22 February 2011, 15:15 »
Thanks for the clarification - however the OP states that he noticed it when parking - it is only activated above 20mph and as I mentioned as soon as you touch the brake or clutch it disengages and the light goes out??
Strange, unless like you say there is a fault with the circuit.
Are you really not sure what cruise control does? The system allows you to maintain a set road speed (of your choice). Useless in town, but on a quiet motorway or through speed controlled areas (like SPECS, the av speed cameras on motorways) it is invaluable.
Offline simond65
« Reply #6 on: 22 February 2011, 17:25 »
Yep, quite happy I know what the Cruise Control does, been using in pretty much the way you describe for the last four and half years - thanks for asking though.
The OP says he noticed it when parking, not sure that means that it only came on when he was parking though, could have come on earlier in the journey. I'm sure he'll be along in a while to clarify.
Strange thing you mention about the dashboard light though, mine stays on as long as it's activated but not set whereas it would seem yours goes out once you hit the brake. Mine's a 56 model so maybe a change in later MYs?
Offline Ed30DSG
« Reply #7 on: 22 February 2011, 17:39 »
That was aimed at the OP :)
Offline simond65
« Reply #8 on: 22 February 2011, 17:46 »
Ah, that makes sense. Thought you were patronising me  :smiley:
Offline Chris MKV
« Reply #9 on: 22 February 2011, 17:54 »
My light is only lit whilst the cc is active - not just switched to on.
I've been a target for 'halfords spec' saxos for almost three years now!
