Author Topic: removing rear axle bushings  (Read 5106 times)
Offline bosco
« on: 15 February 2011, 15:30 »
Anybody have any tips on how to remove them? I have the axle off my mk2 golf and wanted to replace them but how do you get them out?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline SoundillusioN
Re: removing rear axle bushings
« Reply #1 on: 15 February 2011, 15:46 »
THIS any good to you?
Offline bosco
« Reply #2 on: 15 February 2011, 15:54 »
perfect thanks a million shaun
1990 mk2 1.6 daily
« Reply #3 on: 15 February 2011, 16:09 »
No worries.
A million is bit steep though, call it 500k  :grin:
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 15 February 2011, 19:53 »
All this drilling nonsense is wrong - get a blowtorch out and set light to the damned things - much less effort and in a very short time the old rubber and inside metal sleeves will just push out.
« Reply #5 on: 15 February 2011, 20:27 »
Pikey style  :grin:
does that not get messy?
  • Opinions я Us
« Reply #6 on: 15 February 2011, 20:31 »
Only if you set light to the car above the beam.  :grin:
Do it with some old carpet or similar below and it's fine - the molten old bush normally just drips out.
Depending on how pikey you're feeling the shell can often be beaten out in a line, which will tear as you chisel down through it, avoiding any damage to the beam.
« Reply #7 on: 15 February 2011, 20:44 »
Top Tip.
Might give that bash when the time comes. Who doesn't like playing playing fire!?
« Reply #8 on: 16 February 2011, 13:44 »
This has worked for me in the past but be carefull.
Offline mk2bal
« Reply #9 on: 16 February 2011, 15:00 »
I drilled a couple of 10mm holes through mine, then used a hammer and drift and just battered it. As soon as you've broken the rust seal and its moved a mm, it will move easier with every thud thereafter...  Just get tough with it...
