Golf mk2
removing rear axle bushings
Topic: removing rear axle bushings (Read 5107 times)
Andy P
GTI forum regular
Re: removing rear axle bushings
Reply #10 on:
18 February 2011, 17:41 »
My mk2 seems a bit light on the back when turning in at speeds. Does anybody think worn bushes could be the cause? They havent been picked up on the MOT or is this just how mk2's handle
Ben Lessani
The poor mans MK2 Haynes author
Reply #11 on:
27 February 2011, 14:24 »
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg1520093#msg1520093
Drilling it is easy, I used a bit that was the exact gap between the inner and outer sleeve - so when I started the drill, it caught both surfaces, rotated around the centre and removed all 360 degrees of rubber in about 5 seconds.
Mr Blue
Forum addict
Reply #12 on:
27 February 2011, 16:56 »
Blow torch is the way! Hammers out soo easy.
Hardest bit...fitting the new one.
Golf mk2
