Author Topic: broken down ***UPDATE-New head bought!***  (Read 39794 times)
Offline Dave_IOW
Re: broken down *now with vid PAGE 4*
« Reply #50 on: 19 February 2011, 14:51 »
Right After rounding off two of the allen bolts  :sad:  that sit in pulley to remove bottom and middle covers, as i was squeezing out car to punch/kick/beat something, i moved wheel on way out and saw that the belt moved... complete.
So gets out from under car, span wheel, in 5th and belt moved round freely. However the belt has lost about 3 inches worth of teeth.
I take it that this is as bad as the belt snapping and im back to square 1??
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
« Reply #51 on: 19 February 2011, 20:25 »
 :cry: Sorry to say but yes that will have bent valves.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: broken down *update PAGE 6*
« Reply #52 on: 19 February 2011, 22:19 »
Dammit Dave get the car back to Newport and we could have the head off in an afternoon
Offline Dave_IOW
« Reply #53 on: 20 February 2011, 22:13 »
Is it 100% chance the vlaves are bent?
I have turned engine over by spinning wheel in 5th gear and seems to have compression?
Car goes down garage tuesday, they are just going to put a new belt on, then turn it over by hand, if all is good after that, going to try start it.
Wes, who would you send head to to get it rebuilt or would you DIY?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #54 on: 20 February 2011, 22:23 »
The only guy I would get to check the head over and possibly rebuild it would be Snowy out in Calbourne but not sure how busy he is at the mo.
You might have compression on maybe 2 cylinders but chances are at least one valve is bent somewhere. Don't forget the 1.8T has 12 inlet valves and 8 exhaust, 4 more than most 4 cylinder engines.
If you want his number I'll grab it for you. I'm guessing something has seized to cause the teeth to strip...
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #55 on: 20 February 2011, 22:27 »
3 inches worth of teeth is a lot of teeth to lose and cause no damage.. i recon you would have bent at least 2 valves.. they are picked up cheap enough and fit yourself or get a buddy (wez) to do it for you he has nothing to do anyways.. (no alloys or a littleun  :nerd: )
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #56 on: 20 February 2011, 22:30 »
2 kids actually lol
Offline Dave_IOW
« Reply #57 on: 20 February 2011, 22:43 »
Yeah cheers pal, if you could, that would be great.
Worth a chance on the off chance tho just incase luck is with me this time i suppose  :huh:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #58 on: 20 February 2011, 22:46 »
sorry for hijack dave.. but wez aint you got a little littleun like recently ??
« Reply #59 on: 20 February 2011, 23:13 »
Doubt you would have not bent any valves, also very odd to strip the teeth unless something locked up.
